Page 2 of 26
Re: TF1260 New Firmware Alpha Released!
Posted: 17 Dec 2021 19:53
by Cego
terriblefire wrote: 17 Dec 2021 19:27
Cego wrote: 17 Dec 2021 19:20
67 setting in cpuspeed will result in a freeze on my machine. So far 84 and 50 works stable (didnt go higher)
Throughout testing 94 was seen as the best speed
i see, but honestly thats to much for my needs (dont want to stress the CPU and CPLDs). I am happy with 66MHz as all demos will just run fine :)
Posted: 17 Dec 2021 19:57
by terriblefire
PaulJ_2.0 wrote: 17 Dec 2021 19:46 I'm getting nothing from the new firmware on my Rev 2B.
LED power stays dim.
If I revert to previous beta 2021_09_07_999 it's booting fine.
Strange this motherboard...
Been tested on 3 rev 2s. Infact rev2B was the most stable platform.
Posted: 17 Dec 2021 20:01
by chucky
(as 8bitbubsy didnt get any activationmail he mailed me)
Message (from 8bitbubsy):
I got the firmware flashed today, using a Rasberry Pi 4 + xcs3prog. Had to disconnect 3.3v from the Pi and power up the Amiga with the board connected.
It seems to run fine, here are my bustest speeds:
Posted: 17 Dec 2021 20:02
by PaulJ_2.0
terriblefire wrote: 17 Dec 2021 19:57 Been tested on 3 rev 2s. Infact rev2B was the most stable platform.
I'm not sure what it can be. It's not got anything other than a gotek in it.
All timing fixes are present and correct and it's perfectly stable and checks out fine 99.9% of the time. The odd firmware update and it refuses to init.
Posted: 17 Dec 2021 20:09
by supaduper
PaulJ_2.0 wrote: 17 Dec 2021 20:02
With no boot device on the A1200 does it go to the insert floppy rom screen ?
Posted: 17 Dec 2021 20:10
by chucky
After 30ish seconds. (powerled should go to fullbright after 1 sec)
Posted: 17 Dec 2021 20:18
by PaulJ_2.0
supaduper wrote: 17 Dec 2021 20:09 With no boot device on the A1200 does it go to the insert floppy rom screen ?
PaulJ_2.0 wrote: 17 Dec 2021 19:46 LED power stays dim.
It doesn't even start to initialise.
Even Diagrom wont start.
Posted: 17 Dec 2021 20:24
by supaduper
PaulJ_2.0 wrote: 17 Dec 2021 20:18
It doesn't even start to initilise.
any difference if you wait say 40 to 50 seconds before trying to power on again ?
Posted: 17 Dec 2021 20:26
by PaulJ_2.0
supaduper wrote: 17 Dec 2021 20:24 any difference if you wait say 40 to 50 seconds before trying to power on again ?
No, the power stays dim at all times, cold or warm reset.
Same with Diagrom installed, nothing initialises, power just sits at dim.
Posted: 17 Dec 2021 20:31
by supaduper
PaulJ_2.0 wrote: 17 Dec 2021 20:26
You can send back to me to test that way we can eliminate either the Card or your A1200
