Page 2 of 12
Re: Problem with H4 not booting (zChris's board)
Posted: 16 Aug 2021 18:54
PhilC wrote: 16 Aug 2021 17:48
@rubber_jonnie I'd initially thought rom but had forgotten about the LS11 :-D
I specifically remember because I initially didn't install it as I misunderstood the requirements. Then I had major problems and had to add a bodge wire to fix.
Posted: 16 Aug 2021 19:04
by zChris
exxos wrote: 16 Aug 2021 18:48
You need to check that line I highlighted.. but check it on the jumper on your scope and keep pressing reset to see if it changes.
Nothing happens when i press reset on the jumper, it is constantly on 5V. Should it be that?
/zChris
Posted: 16 Aug 2021 19:05
zChris wrote: 16 Aug 2021 19:04
Nope, what about reset pin on cpu ?
Posted: 16 Aug 2021 19:13
by zChris
Reset (Pin 18) goes to low (0v) when reset button is pressed and high (5.2v) when it is released.
/zChris
Posted: 16 Aug 2021 19:39
by zChris
Measuring when the reset button is pressed in i got 0.2 on Pin 23,17,4,3,2. When releasing reset pin 17,4,3,2 went from 0 -> 5V and then down to 0 again. Nothing changed on Pin 23.
/zChrus
Posted: 16 Aug 2021 20:05
by PhilC
@zChris for clarity, you are checking at a dip socket not the plcc one for the cpu?
Posted: 16 Aug 2021 20:10
by zChris
Have i done the calculations correctly here.
6 squares from top to top = 6x20ns=120ns=0.00000012s
Then 1/0.00000012 = 8333333.33333roughly 8.3Mhz ?
- DSC_1374.JPG (259.84 KiB) Viewed 2809 times
/zChris
Posted: 16 Aug 2021 20:11
by zChris
PhilC wrote: 16 Aug 2021 20:05
Im checking in the expansion port. Thats wrong?
/zChris
Posted: 16 Aug 2021 20:36
by PhilC
@zChris no that's fine, just checking so everyone knew.
Posted: 16 Aug 2021 22:00
zChris wrote: 16 Aug 2021 20:10
Just press the measure button and select frequency.. then it will tell you the frequency..
