Page 2 of 3
Re: MC68000 Pinout 51,52,62,63,64
Posted: 23 Mar 2021 18:42
by zChris
No i have not tested one board for themself since im not sure where the CE cable on the dual tos board should be when not using with the decoder.
I have checked for shortcircuits on the socket. The shortcircuit i found is between 49 and 14, from i can see on the schematic these are not used ?
And between pin 14 and 16 i get 142 Ohm.
/zChris
Posted: 23 Mar 2021 18:54
by PhilC
49 and 14 are both VCC so that's fine, 16 is gnd, so that resistance between 14 and 16 is likely ok.
I meant to not use the decoder board or rom board at all, or have you soldered that into the motherboard?
Posted: 23 Mar 2021 19:03
zChris wrote: 23 Mar 2021 18:42
Just put your old ROM's back in... Then at least if the ST boots up, you know the fault is on the ROM board somewhere... If you don't boot, the fault is on the decoder area somewhere.
Posted: 23 Mar 2021 19:51
by zChris
The computer boots with the old roms (6pieces) and MC68000 in the socket.
Can i now remove the roms and put in only the dualrom board instead? Do i need to change CE Select from BOOSTER to GLUE ?
/zChris
Posted: 23 Mar 2021 19:52
by PhilC
Put just the dual tos in first and try it. Without the decoder you don't need to connect the CE if I remember correctly
Posted: 23 Mar 2021 20:03
by zChris
I have now removed the ROMS that worked (6pieces) and put in the DualROM board. I get a white screen with a yellow border. Tried both bank 1 and 2.
/zChris
Posted: 23 Mar 2021 20:30
by DoG
You need to make the motherboard read 2 chip TOS by moving the three solder blobs from 256K to 1M. You will also need a 74LS11 in U68 if it is missing (or something like that).
What motherboard do you got?
Link to some help. Read '6 CHIP TO 2 CHIP CONVERSION'.
Posted: 23 Mar 2021 20:47
by zChris
DoG wrote: 23 Mar 2021 20:30
Link to some help. At bottom.
Aha, alright. Then im gonna fix that. Got C070789-001 REV.D1
Posted: 23 Mar 2021 20:54
by DoG
Sorry. Not at the bottom. I don't know why I wrote that. Read '6 CHIP TO 2 CHIP CONVERSION'.
Posted: 23 Mar 2021 22:02
This was the image he sent me...
Yeah the LS11 is missing.. So DUALTOS board using GLUE decoding wont work...
- dsc-1105.jpg (285.85 KiB) Viewed 4537 times
So what happens with decoder board plugged in with the six chip tos?
