Page 2 of 3
Re: C-Lab MK2 CA401332-002-REVC / Repair/Restore log
Posted: 12 Jan 2021 16:18
by Steve
I have a feeling this poor drive has seen better days, it makes sounds like it's trying to dial-up to SCSI heaven:
Although it did show up as detected once, I haven't able to get it detected again since:
Posted: 12 Jan 2021 16:23
Steve wrote: 12 Jan 2021 16:18 I have a feeling this poor drive has seen better days, it makes sounds like it's trying to dial-up to SCSI heaven:
wow, is the motor actually running ? Kinda sounds like its stuck.
Posted: 12 Jan 2021 16:38
by Steve
It is spinning... just sounds like a dial-up modem when it tries to read.
Posted: 13 Jan 2021 09:46
by stephen_usher
It looks like someone has had it open, given the broken warranty seal.
Posted: 13 Jan 2021 14:27
by MegaSTEarian
Sounds painful :shock:
Hope the customer hasn't got any data in there.
On another note, how easy is to source an HDD like this?
Posted: 13 Jan 2021 17:32
by Steve
I think old small 2.5'' scsi's like this would be hard to find. My customer should have his data backed up to tape so hats good.
I'll be recapping the PSU and motherboard next, I'll post photos when I get to it.
Posted: 22 Jan 2021 20:04
by Steve
BIG UPDATE ON PROGRESS
* Openflops drive installed
* NVRAM replaced
* FPU installed
* Recapped PSU
* Recapped Mobo
* SCSI Terminator installed
* Wait states disabled to increase TOS speed
* Silence fan by wiring to 5v instead of 12, clean dust.
RECAP POWER SECTION
~ BEFORE
~ AFTER
RECAP AUDIO SECTION
~ BEFORE
~ AFTER Using top-quality Nichicon audio-grade golden caps
RECAP MODULATOR SECTION
~ BEFORE
~ AFTER Note: the 470uf C24 cap is installed the / CORRECT / way, as it is marked incorrectly on board/schematics
MAKE UP 4700UF MAIN CAP
SILENCE FAN BY WIRING TO 5v & CLEAN DUST
ADD INTERNAL SCSI TERMINATOR (So external drives still work without internal drive)
INSTALL EXXOS NVRAM
NVRAM FINISHED & CAN SEE NEW FPU IN BACKGROUND
PUT TOGETHER FLASH FLOPPY DRIVE
~ TEST DRIVE
INSTALL NEW CF CARD
MOBO FINISHED BEFORE RE-ASSEMBLY
TESTING BEFORE CASE FITTING
CLEANING
Cleaned and disinfected with 99% IPA & Keyboard vacuumed of any dust
Posted: 22 Jan 2021 20:12
by Steve
WAITSTATES DISABLED FOR FASTER TOS SPEED
PSU RE-CAP
Posted: 22 Jan 2021 20:20
Assume you replaced the ROM ? The original ROM will bottle out after a few hours normally.
Posted: 22 Jan 2021 20:27
by Steve
exxos wrote: 22 Jan 2021 20:20 Assume you replaced the ROM ? The original ROM will bottle out after a few hours normally.
I checked and this rom has the exact same serial number as the one in your store, so I think it is a fast rom (assuming serial number is a factor) I will of course run benchmarks and tests in the next few days.
@exxos check the fan silencing photo, you can see the ROM there.
