I have been looking into alternative pastes.. Ironically the current paste composition actually matches the paste I am currently buying in the UK anyway... After talking to the manufacturer, their smallest syringe is still marginally too big to fit the printer :cry: Bizarrely the printer manufacturer actually sells empty cartridges so I purchased a pack of those and some other bits...
All I did was transfer the paste out of one syringe into the printer size syringes... I was a bit worried about airballs and such but it did not seem to be a problem...
- IMG_5871.JPG (210.1 KiB) Viewed 4736 times
Next I realise you cannot fill these cartridges more than about halfway :roll:
- IMG_5872.JPG (166.48 KiB) Viewed 4736 times
So had to take some paste back out again...
- IMG_5873.JPG (234.86 KiB) Viewed 4736 times
I also purchase some disposable nozzles.. But I don't know why, but the paste just seems to get stuck in these incredibly easily
:roll:
- IMG_5874.JPG (256.63 KiB) Viewed 4736 times
It seems to come out perfectly well for a short time and then just blocks up to the point where suitable forces needed to get the paste flowing again..
- IMG_5875.JPG (339.97 KiB) Viewed 4736 times
Later I used the metal nozzle which came with the printer, which again seems to get damaged when putting the protective cap on the thing :roll: after straightening it out it just simply snapped off... But in this case I actually wanted a slightly larger hole anyway, so I think it actually worked out as a good thing :lol:
I was doing some experiments with my 30pin simms... If you look closely from left to right the paste seems to get less and less..
But amazingly, and thankfully, the printer software has a compensation feature which over time you can apply a percentage of extra pressure to compensate for such problems.
- IMG_5877.JPG (255.07 KiB) Viewed 4736 times
This is after reflowing on the printer itself... Overall I will probably need more solder on the pads, but I was really just trying to get the whole thing working to some degree before anything else..
- IMG_5878.JPG (283.4 KiB) Viewed 4736 times
Mostly I was working on the philosophy of a larger nozzle will mean faster prints.. And after talking to the manufacturer, there is not actually a setting for nozzle sizes or anything like that... BUT.. There are ways of getting around this problem... For example a larger nozzle will require less pressure otherwise it will come out too fast, and I can easily adjust the pressure and flow rates etc you can also control how many "passes" of paste goes on each pad in the software.. And another fiddle is the actual paste on the PCB file can be changed.
The problem overall is that while I have the printer maxed out speed wise, it still takes over five minutes to bring the pace on a single simm :( It would basically take 10 minutes to paste 2 up.. Whereas if I paste them by hand manually with a stencil and my rig, it does not really take more than a minute.. But again the problem overall is that even just 10 sets of simms is 40 simms which have to be pasted.. This is one reason why my Simms of been out of stock for so long because it really takes its toll on my fingers :( so the printer is the only real alternative to doing this work anyway..
But it does not necessarily mean the overall job will take longer.. As pasting stuff by hand is subject to errors and smudges and basically all sorts of failures and shorts which I then have to spend time fixing... Theoretically the printer should do a consistent job across all of them and reduce the amount of fixing time I will need to spend later on. Of course other than placing the PCB on the printer bed itself, those five or 10 minutes I can actually spend doing something else anyway.. So I'm not overly bothered about the slow printing.. But considering it takes to force an entire day to assemble 40 simms.. Then another couple of days testing and fixing... It would unfortunately mean pasting an assembly may well end up taking a lot longer.
After some research I have found some nozzles in the UK which I think will fit the syringes in the printer.. These are massively cheaper than like £20 a pop on the proper ones.. though finding some low profile ones has been a bit of a challenge.. Anyway, I have ordered some 0.25mm and 0.5mm tips.. 0.25mm is the default size for the printer and the ones I am currently using.. I went with 0.5mm then multiplied by pie and chips or something will increase the flow rate more than 3 times. I'm hoping the larger nozzle will help prevent the flow problems with the paste, and I also hope I can fiddle the printer to do less passes on each pad and put more paste down every single pass.. So I really hope I can get the paste time down to for like two or three minutes...
I think the only possible problem I may end up with, is I need more paste on the simm contacts than on the DRAM pads.. Putting based on the DRAM pads may well end up to much.. But saying that the stencils I was using down way too much paste anyway... Some hoping I can just do a single quick pass on the DRAM pads, and maybe 3 passes on the simm pads... I guess it is a bit like setting up a 3-D printer, that everything has to be set up perfectly to get the results you want..
