Re: Desoldering Falcon NVRAM
Posted: 21 Sep 2018 22:48
No need for Right Shift.
Totally OK also during RAM test....during boot, before RAM test.
We welcome retro users & hardware gurus alike! Come and join the party :)
https://www.exxosforum.co.uk/forum/
When opening my Falcon, it turned out the Dallas chip doesn't use a package with pins that could easily be reached (and cut):exxos wrote: 21 Sep 2018 21:40 My video was done to try and prevent damages to the boards as a lot of people are not good at this stuff. Sure more qualified people could do different methods.. but as many found, including myself, using a solder vacuum can easily damage pads, its why I avoided it in my video. Cutting pins and doing things one at a time means people will not start levering the NVRAM with a screwdriver, breaking the motherboard, ripping vias out etc when the NVRAM doesn't come out freely. I've fixed many boards due to such damages.
No objection if you want do a video, but have to think about who are not good at soldering, and how they will likely damaged everything, every step of the way. That is why I did the video, and the methods I did.
Cut the case off..pixelpusher wrote: 19 Jan 2020 13:44 When opening my Falcon, it turned out the Dallas chip doesn't use a package with pins that could easily be reached (and cut):
Any suggestion how to proceed here?
Yes, I had to borrow a board heater that sets under the board and brings board temp up close to solder melting and then use wick and an iron on top with more solder and flux. I really believe it was the worst extraction I've ever done.exxos wrote: 19 Jan 2020 15:19 @PaulJ yeah the gnd pin takes a lot of heat. In some cases it took my gas iron and soldering iron to remove it.
