Page 2 of 7
Re: ReAgnus Board (Design Complete)
Posted: 26 May 2020 18:18
by neilo40
Fantastic! Are you planning to engineer the firmware from scratch or start with one of the existing (non cycle accurate) implementations, like minimig?
Posted: 26 May 2020 18:52
by a500king
Awesome idea and the board looks sweet.
Will you be releasing the Verilog/VHDL rtl source?
Beyond a physical board, cycle-accurate replacement modules will help a variety of causes like other FPGA-based amiga reimplementations.
Thanks for your efforts!
Posted: 26 May 2020 18:55
by terriblefire
I'm planning to do a re-implementation but of course i'll just start with a compile of Minimig to get going.. or maybe aoOCS. I think that code is cleaner anyways.
After i have a baseline to prove it works i'll get traces on the Logic analyser and watch the cycles with real agnus vs re-agnus.
I'll release it all but with the usual 6 month delay to keep the parasites from making a quick buck.
Posted: 26 May 2020 20:39
by a500king
Here's what I use for capturing Agnus traces on my HP 16700s and 16900:
https://www.techtravels.org/2013/03/bug ... -on-agnus/
- Bug Katcher on Agnus
- bug_katcher_installed.jpg (233.38 KiB) Viewed 9567 times
Posted: 26 May 2020 21:54
by Aeberbach
Amazing, Amiga will never die as long as people keep doing great projects like this.
(Chucky's 1.5 ReAmiga release got me started on a new machine also)
Posted: 26 May 2020 22:15
by terriblefire
Maximilian wrote: 26 May 2020 16:41
Thaty is an amazing project, :D
(wasn't someone else doing the same?)
@Icky has a similar board for the H4 but based on MAX 10 chips.
Are there any pins over on the FPGA and the bus buffers?
If wired to a couple of pads those could be used for upgrades or feature selection like Pal/Ntsc.
Just a thought..
Yeah i am toying with ideas for stuff like that but TBH right now the goal is just to compile minimig into it.
Posted: 26 May 2020 22:17
by terriblefire
i'd thought about this then realized almost all of those pins come out to the either the 68000 socket or the ram expansion socket.
Posted: 27 May 2020 00:11
by terriblefire
5 pieces are ordered with partial assembly. Without buffers or fpga they were £7 each.
Remaining BOM is 1 x ICE40 FPGA. 10 x bus buffers. 10 x 100nF 0805 Caps
Posted: 27 May 2020 02:09
by Maximilian
Found it (German):
https://www.forum64.de/index.php?thread ... /&pageNo=1
Not a lot of info on it, he digitized high res die pictures and used his software to reproduce a schema.
He is using a MAX10 chip also, but he's very busy so his project will probably te some time to complete....
Posted: 27 May 2020 08:20
by terriblefire
Maximilian wrote: 27 May 2020 02:09
Found it (German):
Ok cool. I have the schematics in pdf form and a few other sources.
But the first thing to do for me is get the whole thing running roughly with Minimig/aoOCS etc. Just to prove the hardware works.
