Page 2 of 2
Re: DEVPAC 68881 required error
Posted: 20 Jun 2019 11:37
OK I figured it out.. Seems to be I have to put NONE for debug symbols..
Now the files match 100% :D :D
Its taken so long to figure the compiler out that I can't remember why I wanted to do all this in the first place :lol:
Posted: 20 Jun 2019 17:28
by mrbombermillzy
czietz wrote: 20 Jun 2019 09:52 EDIT: Also I wonder if the combination of 68040/68881 is even allowed in Devpac, considering that the 68040 has a builtin FPU.
I've got a feeling that what czietz touched on here may cause some problems due to the 040 having a subset of, or emulating some 68881/2 commands.
Watch out! ;)
Posted: 20 Jun 2019 17:35
No idea, d.m.l wrote the code. It works on the Falcon (030) and CT60 with FPU's. Though its the same code as used in GB6 for the past 3 years and not aware of any issues yet.. I know doug wrote a lot of FPU routines and let me decide which to use. So I went with the most compatible ones, so likely it could already be sorted out.
Posted: 21 Jun 2019 06:34
by mikro
czietz wrote: 20 Jun 2019 09:52EDIT: Also I wonder if the combination of 68040/68881 is even allowed in Devpac, considering that the 68040 has a builtin FPU.
I guess it's harmless - there isn't a 68881/2 instruction which isn't allowed on the 040 (natively or via emulation). IIRC there is only one or two opcodes which have the same syntax but are different on 030 and 040/060 CPUs and none of them is an FPU instruction.
