Page 2 of 9
Re: Floppy Support
Posted: 15 Nov 2018 10:51
exxos wrote: 15 Nov 2018 10:49
Looks like the top slots half melted together at the top.. will see if I can open them up with a knife...
Doesn't look too bad though, how does it compare to an original, and does it actually fit? More importantly, does the screw go through the middle!
Re: Floppy Support
Posted: 15 Nov 2018 10:53
Looks like it needs to be about 1mm taller overall.. also the slots need making twice the size..
- IMG_3529.JPG (286.16 KiB) Viewed 4043 times
- IMG_3530.JPG (317.5 KiB) Viewed 4043 times
Re: Floppy Support
Posted: 15 Nov 2018 10:55
rubber_jonnie wrote: 15 Nov 2018 10:51
Doesn't fit, but there is no "give" because of the "fused" slots most likely..
screw... means getting up and going looking... :roll: :lol:
Re: Floppy Support
Posted: 15 Nov 2018 10:59
Might be ok for a long button machine, I believe they are shorter.
I can easily make another model that's taller. As for the slots, I will print one out at home to see what's what, they were very narrow on the post I used to get the dimensions, so I'll need to have one in my hands to figure it out properly. Yours look about 1mm. I can probably add a chamfer to help it go into the hole.
Not bad for a first go though. Nothing too hard to fix.
Screws are 3mm I think, and hole is 3.8, so should be fine. When I have printed one I will check.
Re: Floppy Support
Posted: 15 Nov 2018 11:24
by Maeke
Try to print it slower, let's say 30mm/s
Re: Floppy Support
Posted: 15 Nov 2018 12:58
Maeke wrote: 15 Nov 2018 11:24
Will do!
Re: Floppy Support
Posted: 15 Nov 2018 13:00
Tried screw, the whole is the right size, but because the smaller end of the thing is a little scrappy with the print, the screw will not go right the way through...
It is probably also a point that if the end is going to be squashed once inserted into the motherboard, the hole will actually be even smaller.. So it might be a idea to make the end hole where the cutout groove is, a fraction larger to give it a little bit more play room.
Re: Floppy Support
Posted: 15 Nov 2018 13:07
Settings I printed before was...
- old.jpg (52.14 KiB) Viewed 4010 times
That is a little "fast" for delicate work I think...
So I halved it and trying again...
- new.jpg (52.33 KiB) Viewed 4010 times
So print time before was 18mins, now its 28mins.
Re: Floppy Support
Posted: 15 Nov 2018 13:12
exxos wrote: 15 Nov 2018 13:00
Will try as soon as I can :)
Re: Floppy Support
Posted: 15 Nov 2018 13:13
Be interested to see the results, Lee Ashmore on FB has suggested .2mm for the layer for strength.
