Page 2 of 5
Re: exxos finally in the game!
Posted: 18 Oct 2018 18:08
by PhilC
Good idea with the video board, I removed all of the black plastic spacers when I did mine.
Posted: 18 Oct 2018 18:34
by Icky
Forgottenmyname wrote: 18 Oct 2018 18:08 Good idea with the video board, I removed all of the black plastic spacers when I did mine.
Snap - I did to and then it made it more difficult to line the pins up when putting the video board into the main board.
Exxos - while you have the soldering iron out might want to desolder the XTAL and put in a socket so you can replace with other XTALs
Posted: 18 Oct 2018 18:52
Icky wrote: 18 Oct 2018 18:34 Snap - I did to and then it made it more difficult to line the pins up when putting the video board into the main board.
Yep! :lol:
Icky wrote: 18 Oct 2018 18:34 Exxos - while you have the soldering iron out might want to desolder the XTAL and put in a socket so you can replace with other XTALs
Yeah, I need to take this out anyway as the assembly company did not solder that resistor which half goes under it..
Posted: 18 Oct 2018 19:54
16MHz fix done.
Posted: 18 Oct 2018 19:57
GLUE PATCH DONE
(Forgot to take a image of the long wine which goes to the DMA 's resistor pack)
Posted: 18 Oct 2018 20:15
by Icky
You are on fire tonight Exxos. You’ll have this patched before the days end at this rate
Posted: 18 Oct 2018 20:18
by sandord
exxos wrote: 18 Oct 2018 19:57 GLUE PATCH DONE
You're ticking off @troed just like that?
Posted: 18 Oct 2018 20:23
sandord wrote: 18 Oct 2018 20:18 You're ticking off @troed just like that?
I think troed is away on business for the next couple of weeks.
Posted: 18 Oct 2018 20:24
Icky wrote: 18 Oct 2018 20:15 You are on fire tonight Exxos. You’ll have this patched before the days end at this rate
Yeah, burnt my finger :P
MFP RESISTOR FIX
Some chips and connectors now on...
