Page 2 of 3
Re: derkom - Progress
Posted: 13 Oct 2018 13:10
by derkom
16MHZ OPTIONAL FIX
- bodge4.jpg (169.44 KiB) Viewed 9239 times
Got the wire a little too hot here and melted back the insulation further than I'd like, but nothing risky is nearby, so it'll do.
(Yes, I did just cut that resistor off at the board instead of desolder it.)
Posted: 14 Oct 2018 11:41
by derkom
Quick question about the
GLUE DATALINE FIX...
In step 1, it says, "Cut D0 & D1 tracks on the bottom of the PCB" and the red indicator covers two tracks in the picture:
- cc1.JPG (322.61 KiB) Viewed 9216 times
Is it correct to cut
both tracks covered by the red line, not just the yellow track? Since the instructions say to cut D0 and D1, and the non-yellow track goes to D0, I think I know the answer, but I want to double check with you guys before I cut. :?
Posted: 14 Oct 2018 11:49
Yes, cut both tracks :)
If you zoom the image, you can see D0 & D1 on the IC holes.
Posted: 14 Oct 2018 11:51
by derkom
exxos wrote: 14 Oct 2018 11:49
Yep, I did see the labels. Just wanted to be ultra-sure before cutting. Thanks! :)
Posted: 14 Oct 2018 11:55
derkom wrote: 14 Oct 2018 11:51
Always a good plan! :)
Posted: 25 Jul 2019 16:41
by derkom
So, life got in the way and kept me away from this project for a long time. I've finally picked it up again and made some progress, although I'm not getting video (more on this later).
For now, various pullups and the GLUE dataline patch (don't ask about the bits in the corner):
- IMG_20190725_183042.jpg (107.77 KiB) Viewed 8639 times
- IMG_20190725_183933.jpg (89.03 KiB) Viewed 8639 times
Posted: 25 Jul 2019 16:45
by derkom
MFP fix, keyboard resistor fix, ACIA dataline fix ...
- IMG_20190725_184248.jpg (93.12 KiB) Viewed 8638 times
Posted: 25 Jul 2019 16:48
by derkom
RAM RW fix ...
- IMG_20190725_184659.jpg (97.2 KiB) Viewed 8638 times
Posted: 25 Jul 2019 16:51
by derkom
1772 IRQ typo fix ...
- IMG_20190725_184944.jpg (56.4 KiB) Viewed 8638 times
Posted: 25 Jul 2019 16:54
by derkom
Floppy pullups fix ...
- IMG_20190725_185233.jpg (270.03 KiB) Viewed 8637 times
