Page 2 of 28
Re: Video driver thoughts
Posted: 19 Oct 2018 21:25
by rpineau
Yes, that's a good idea, probably only needed for the bit 3 and 4 as after that the increase will be very small.
Posted: 19 Oct 2018 21:26
by PhilC
At last, an opportunity for a triple decker. Now do I put it over or under the ram board :D
Posted: 19 Oct 2018 21:30
Forgottenmyname wrote: 19 Oct 2018 21:26 At last, an opportunity for a triple decker. Now do I put it over or under the ram board :D
Don't follow what you mean ?
Posted: 19 Oct 2018 21:37
by PhilC
exxos wrote: 19 Oct 2018 21:30
Well I already have the shifter in the adaptor board for your ram expansion.
Posted: 19 Oct 2018 21:40
Forgottenmyname wrote: 19 Oct 2018 21:37 Well I already have the shifter in the adaptor board for your ram expansion.
oh yep :lol:
Posted: 19 Oct 2018 21:44
More of a final draft...
..with something like this...
Posted: 19 Oct 2018 21:56
by rpineau
I'm not sure about C1, C2 and C3 inline with RGB, the Falcon has 75 ohm resistors inline to match standard line impedance for video signals.
Are you doing this to eliminate any potential DC in the signal ?
Posted: 19 Oct 2018 22:02
rpineau wrote: 19 Oct 2018 21:56 I'm not sure about C1, C2 and C3 inline with RGB, the Falcon has 75 ohm resistors inline to match standard line impedance for video signals.
I'm doing it because that what it says in the datasheet.... I to am not sure why the falcon is wired up differently..
Posted: 19 Oct 2018 22:12
by rpineau
Works for me .. I think the datasheet is probable more accurate than what was done on the falcon :)
Posted: 19 Oct 2018 22:18
rpineau wrote: 19 Oct 2018 22:12 Works for me .. I think the datasheet is probable more accurate than what was done on the falcon :)
Hopefully :) Easy to bridge them over if needs be anyway.
