| • Gettime | Gets the date and time. |
| • NVMaccess | Configures the NVM of the real-time clock. |
| • Settime | Sets the date and time. |
| • Xbtimer | Initializes the system timer. |
| Name: | »get time« - Get the time and date. | ||||||||||||||
| Opcode: | 23 | ||||||||||||||
| Syntax: | uint32_t Gettime( void ); | ||||||||||||||
| Description: | The XBIOS routine Gettime obtains the date and time from the computer's hardware clock. | ||||||||||||||
| Return value: | The function returns the date and time, which are coded as
follows:
| Availability: | All TOS versions. | ||||||||||||||
| Group: | Date, Time and Timer | ||||||||||||||
| See also: | Binding Settime |
| C: | #include uint32_t Gettime( void ); |
| Assembler: | move.w #23,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #2,sp ; Correct stack |
| Name: | »NVMacess« - Configure the "Non-Volatile Memory" of the real-time clock. | ||||||||||||||||||
| Opcode: | 46 | ||||||||||||||||||
| Syntax: | int16_t NVMaccess( int16_t op, int16_t start, int16_t count, int8_t *buffer ); | ||||||||||||||||||
| Description: | The XBIOS routine NVMaccess permits the configuration of the
NVM of the real-time clock. This has available 50 bytes of
non-volatile RAM, where the last two bytes are used as a checksum. The
following apply:
| Return value: | The function returns the value 0 if no error has occurred. A value of -5 means that the arguments were not within the permitted region. A return value of -12 identifies an inconsistent checksum. | ||||||||||||||||||
| Availability: | Atari TT (TOS 3.xx) and Falcon (TOS 4.xx) | ||||||||||||||||||
| Group: | Date, Time and Timer | ||||||||||||||||||
| See also: | Binding Assignment of the NVM |
| C: | #include int16_t NVMaccess( int16_t op, int16_t start, int16_t count, int8_t *buffer ); |
| Assembler: | pea buffer ; Offset 8 move.w count,-(sp) ; Offset 6 move.w start,-(sp) ; Offset 4 move.w op,-(sp) ; Offset 2 move.w #46,-(sp) ; Offset 0 trap #14 ; Call XBIOS lea $C(sp),sp ; Correct stack |
| Name: | »set time« - Set the time and date. | ||||||||||||||
| Opcode: | 22 | ||||||||||||||
| Syntax: | void Settime( uint32_t time ); | ||||||||||||||
| Description: | The XBIOS routine Settime sets the date and time. The 32-bit
parameter time is split up as follows:
| Return value: | The function does not return a result. | ||||||||||||||
| Gruppe: | Date, Time and Timer | ||||||||||||||
| See Also: | Binding Gettime |
| C: | #include void Settime( uint32_t time ); |
| Assembler: | move.l time,-(sp) ; Offset 2 move.w #22,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #6,sp ; Correct stack |
| Name: | »timer init« - Initialize the timer in the MFP chip. | ||||||||||||||||||||
| Opcode: | 31 | ||||||||||||||||||||
| Syntax: | void Xbtimer( int16_t timer, int16_t control, int16_t data, void(*vector)( ) ); | ||||||||||||||||||||
| Description: | The XBIOS routine Xbtimer initializes one of the four timers
(A-D) in the 68901 multi-function peripheral chip. The following
apply:
| Return value: | The function does not return a result. | ||||||||||||||||||||
| Availability: | All TOS versions. | ||||||||||||||||||||
| Group: | Date, Time and Timer | ||||||||||||||||||||
| See also: | Binding |
| C: | #include void Xbtimer( int16_t timer, int16_t control, int16_t data, void(*vector)( ) ); |
| Assembler: | pea vector ; Offset 8 move.w data,-(sp) ; Offset 6 move.w control,-(sp) ; Offset 4 move.w timer,-(sp) ; Offset 2 move.w #31,-(sp) ; Offset 0 trap #14 ; Call XBIOS lea $C(sp),sp ; Correct stack |
The real-time clock in the Atari TT030 and Falcon030 has available 50 bytes of non-volatile memory that can be used by programs for configuration purposes. The following assignments apply:
unsigned int bootpref;
char reserved[4];
unsigned char language;
unsigned char keyboard;
unsigned char datetime;
char separator;
unsigned char bootdelay;
char reserved2[3];
unsigned int vmode;
unsigned char scsi;
} NVM;
| bootpref | Boot preference:
0x00 = No preference 0x08 = MagiC 0x10 = Linux 0x20 = NetBSD 0x40 = UNIX will be booted 0x80 = TOS will be booted | ||||||
| language | Language:
0 = English 1 = German 2 = French 3 = Reserved 4 = Spanish 5 = Italian | ||||||
| keyboard | Keyboard layout:
0 = USA 1 = German 2 = French 3 = British 4 = Spanish 5 = Italian 6 = Swedish 7 = (French) Swiss 8 = (German) Swiss | ||||||
| datetime | Formatting of the date:
| separator | ASCII-value of the character that is to act as the separator for the date. | ||||||
| bootdelay | Boot delay | ||||||
| vmode | Video mode
| scsi |
All further bytes are not documented at present. As one can see, it is possible, in particular, to specify the SCSI ID of a TT030 or Falcon030 via the NVM.
In a Milan the NVM has a size of 224 bytes.
The following structure applies only for TOS 4.08 (2003-03-09) and Bootblock 1.02!
char reserved[4];
char separator;
unsigned char ide_drives;
unsigned char scsi_drives;
char reserved2;
unsigned int vmode;
unsigned char scsi;
char reserved3[31];
unsigned char memory;
char INT1_2;
char INT3_4;
char reserved4[173];
} NVM_Milan;
| memory |
See also: NVMaccess XHDI specification
