Well I wanted to see how well the keyboard works, and it all works fine:
It's only assembled with the 2 screws holding in the mainboard, but it's enough to test.
One small problem is that some of the keys are sticky, so I likely need to clean and lubricate the stems to get things going smoothly before I reassemble for good.
That won't happen until the memory upgrade is done though, but I really wanted to try it all together :)
Keyboard now working lovely after a bit of a clean and a little lube :)
In the old ROM the function keys allowed setting of 40/80 column, but the EXOS 2.04 ROM doesn't, but it seems the commands 'text 40' and 'text 80' do the same thing.
Need to do a little reading on what options BASIC has.
I did find the manual on-line. Not sure where though.
Also, you have "OS" commands available to you within BASIC using the ':' operator. It's basically the same as '*' on the BBC. So, ":help" will list the ROMs and versions and give you help in the same way as "*HELP" on the Beeb.
stephen_usher wrote: Mon Aug 10, 2026 8:23 pm I did find the manual on-line. Not sure where though.
Sounds interesting, will go and have a look for the user manual.
Manual found on archive.org.
A quick skim through and it seems to be quite a decent bacsic and well thought out machine.
I like that each function key has up to 4 options:
F key
Shift+F key
CTRL+F Key
ALT+F key
And all do differrent things. Seems like a decent version of BASIC as far as I can see.
Being able to use the joystick for editing is pretty cool too.
Enterprise_Programming_Guide.pdf
(30.24 MiB) Downloaded 5 times
!Message from: Moderator
@rubber_jonnie, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
Thought a size comparison with the Speccy might be interesting:
I'd always imagined the Enterprise being a lot bigger.
Hmm, I'm a little concerned.
If I leave it running for a period of time, I get screen corruption.
For example, I leave it running a program that prints out characters to screen, and it eventually crashes.
I think I'll need to get the thermal camera on it, see if there is a bad RAM IC, I do hope it isn't a custom IC.
Will get pictures soon but I have the G7000 on the bench just now.
mrbombermillzy
Post by mrbombermillzy »
rubber_jonnie wrote: Tue Aug 11, 2026 10:19 pm For example, I leave it running a program that prints out characters to screen, and it eventually crashes.
Probably not the case 99% of the time in this situation but just to check; its definitely not a buggy program, right? :D
mrbombermillzy wrote: Tue Aug 11, 2026 10:29 pm
Nope, pretty simple for/next loop with no weird characters as far as I can tell...
Type the program in here. I'll see if it replicates on my machine after a similar period.
