And as per normal I have no BC212's...rubber_jonnie wrote: Fri Oct 30, 2026 2:19 pmYep I'm planning to do that as well. As for T2 it's on it's 4th TR2...PhilC wrote: Fri Oct 30, 2026 2:11 pm When I got my Enterprise, it recommend replacing both tr2 & 3, so amongst other things I've done that as well.
Seeing as TR2 is merely generating an AC resonance to cause an AC supply to the transformer and doesn’t carry the current used by the secondary 12V supply it’s likely that input ripple is hitting a resonance. This would boost the current going through the transistor.
The circuit coukd probably also do with a diode to redirect the back emf coming from the inductor when the field collapses.
Yes to the diode for sure!!!stephen_usher wrote: Fri Oct 30, 2026 3:42 pm Seeing as TR2 is merely generating an AC resonance to cause an AC supply to the transformer and doesn’t carry the current used by the secondary 12V supply it’s likely that input ripple is hitting a resonance. This would boost the current going through the transistor.
But where would it go?
Can't recall, did the Speccy ahve a diode for back EMF protection?
I'd have to look at a load of Big Clive videos to work that out.rubber_jonnie wrote: Fri Oct 30, 2026 3:57 pmYes to the diode for sure!!!stephen_usher wrote: Fri Oct 30, 2026 3:42 pm Seeing as TR2 is merely generating an AC resonance to cause an AC supply to the transformer and doesn’t carry the current used by the secondary 12V supply it’s likely that input ripple is hitting a resonance. This would boost the current going through the transistor.
No idea... probably not as that would have added costs. There are later, better, versions of the DC-DC circuit on the Issue 6 boards which can be retro-fitted which make it more reliable. I guess that may add diode protection.Can't recall, did the Speccy ahve a diode for back EMF protection?
Yeah I've seen him mention it a lot in his vids.stephen_usher wrote: Fri Oct 30, 2026 10:13 pm I'd have to look at a load of Big Clive videos to work that out.Basically, it's to stop backwards current trying to go through the transisotr, but around the coil area.
There are power replacement boards so I've been told over on the Enterprise forum but I can't find anything about them yet.stephen_usher wrote: Fri Oct 30, 2026 10:13 pm No idea... probably not as that would have added costs. There are later, better, versions of the DC-DC circuit on the Issue 6 boards which can be retro-fitted which make it more reliable. I guess that may add diode protection.
OK, so here's the plan for the power circuit.
I'm going to replace D4 and fit a bi-polar cap at C9 (As recommended on the Enterprise forum) and then re-solder the remaining components as the solder does look a bit dodgy.
So these:
L1
TR2
TR3
R13
R14
R15
R16
Will get de-soldered and re-soldered with fresh. I will also remove L1 and clean underneath it in case there are still silty remnants there.
I'll also replace TR3 just in case.
C10 has already been replaced and is correctly oriented.
Hopefully the parts will be here tomorrow though I can get the resistors re-soldered and L1 done before that.
So these:
L1
TR2
TR3
R13
R14
R15
R16
BC212's (TR3)arrived today, so that's installed, and I temporarily installed the old D4 just to do a test. All the resistors have been removed and checked, then re-soldered.
L1 is also re-soldered, and all silt underneath it is gone and I have to say there was quite a bit.
Also the solder for all of the parts looked very similar to capacitor corroded solder, I think as a result of whatever the flood/silt etc contained and where it landed on the PCB.
All the solder looks way better now.
Just waiting on the C9 bi-polar cap replacement and the D4 replacement, but so far it's looking good.
Well the bi-polar caps and D4 replacement arrived yesterday and have now been installed:
It's all back together now for a burn in test. Lets hope that isn't literal!!!
Summary of work done:
Removed L1 and cleaned underneath and reinstalled.
Removed R13, R14, R15 & R16 and cleaned underneath and reinstalled.
Replaced TR2 & TR3.
Replaced D4
Replaced C9 with a b-polar cap as recommended over at Enterpriseforever.com.
I can't help but think the weird effect the silt had on the solder on that corner of the board had a part to play (It looked a bit like how cap juice affects solder), but now all the parts have been removed, some replaced and fresh solder and a clean PCB all around the area I hope it'll remain good.
I do also wonder if some of the silty remains may have been a little conductive too, but at least they are all gone now.
Fingers crossed hey, only time will tell.
Replaced TR2 & TR3.
Replaced D4
OK, so after all my work on the power circuit, I discovered something interesting. My composite mod, which the other machine doesn't have, was hooked up to the modulator for both 5v and the composite signal.
I'd used this as a lash up during initial testing, and as it worked fine I left it in place. Image quality was poor, but workable if you just wanted to know if the machine had booted.
But yesterday, it killed another BC337 (Not badly, so no magic smoke), a symptom of which is wonky video, and so I disconnected the comp mod after replacing TR2 and looked for alternate composite hookup points.
5v I tapped from a nearby power rail and I took the video signal from R101 where it is fed by TR8. Image quality is vastly improved now over composite and whilst I am concerned it may still be an issue for TR2 I am going to monitor and I'll report back any further issues.
I suspect the janky video quality may have been an indicator that something I was doing was wrong, but I think what I experienced showed me the way.
Nonetheless the machine seems better but I will monitor.
Aaand another dead BC337...
I'm going to disconnect the comp mod completely.
