I will spend some time with it to see if there are shorts I may have missed. Might have to remove IC's to see if there is anything bridged underneath.
Could be a "phantom short" caused by flux which has become conductive.
stephen_usher wrote: Thu Apr 30, 2026 6:15 pm
Possibly, I need to have a good look but I did give it a damn good clen.
I found an earlier incarnation that uses a bigger PCB and through hole components, so I've ordered those via a project on PCBWay so at least the creator will get something back.
In the meantime I do wonder if there is a short somewhere in the PCB from the solder paste I used, so I think I'll use a spare PCB and transfer over the components and either hand solder or hot air solder them on but not using solder paste.
No harm doing so, and what I might do is remove one IC at a time to see if a particular one is causing the machine to hang.
Also, my expansion slots are in the UK so that should be coming soon
HigashiJun wrote: Tue May 05, 2026 1:49 pm
Cannot wait seeing the final result.
Me either!
Well the connectors arrived today and they look spot on:
They aren't soldered in yet as I've been in London all day, but they fit perfectly so pleased with the result. I think I'll wait until I have one of the expansion boards before I solder them all in as with 86 pins each, that's a lot of soldering if the expansion cards don't fit!!!
The PCB's for the alternate CDP1861 are nearly done, 93% according to the order so fingers crossed I'll have those relatively quickly as I did cheap out on the postage
EDIT: PCBs just shipped.
As I'm away next week it'll probably mean I won't be able to build until I get back, and I'll be away 10 days...
I guess we'll all just have to be patient
Unfortunately whilst I may have the GALs I'm not sure about the rest, so that will have to wait until i get back from hols.
