Another Camputers Lynx project
Re: Another Camputers Lynx project
I decided whilst I've got the Lynx on the desk to check the power supply.
After drilling out 7 rivets, 4 for the case, 3 connecting the three voltage regulators to the case, that I'd give it a test and see how the capacitors are holding up.
It actually looks to be in great condition internally, so I'll test the caps and replace them if needed, then tap out the holes left by the rivets and fit bolts instead.
For those who are interested (if anyone :lol: ) regulation is done by three LM3402s, 12v,5v and -5v
Edit: And the good news is the caps all checked out just fine. I've now put it all back together. Tapped the case screws out to M4 and fitted nuts and screws to the three voltage regulators.
All back together and now running fine once again.
PhilC wrote: 05 Apr 2026 15:58 I decided whilst I've got the Lynx on the desk to check the power supply.
That's a chonky boy!
peters
Post by peters »
I do remember the PSU got rather hot and there are no vent holes.
peters wrote: 06 Apr 2026 10:30 I do remember the PSU got rather hot and there are no vent holes.
Yeah I'm not surprised with those three voltage regulators using the case as their heatsinks
I presume rectification is done by 4 diodes rather than a single bridge rectifier?
rubber_jonnie wrote: 06 Apr 2026 12:41 I presume rectification is done by 4 diodes rather than a single bridge rectifier?
It looks that way. I didn't really look, was too busy drilling and tapping.
PhilC wrote: 06 Apr 2026 15:07
Stupid rivets...
I think possibly my TRS-80 Model 1 PSU had rivets as well, though I can't recall 100%.
Users browsing this forum: CCBot, Icky and 29 guests
