ATW800/2 in a MonSTErbo powered STE
HigashiJun
Re: ATW800/2 in a MonSTErbo powered STE
Post by HigashiJun »
Darklord wrote: Sun Mar 22, 2026 12:54 pm Good luck with this project - it looks like it's coming along nicely. :)
Thanks !
And just in case, here is a link to the TwiSTEr page (in German only):
https://wiki.newtosworld.de/index.php?title=TwiSTEr
HigashiJun
Since Cyril from 16-32bit.eu made a new batch of his Power PSU for the ST series, I picked up one for my Monsterbo powered STE.
Looks good in black:
And even matches the Monsterbo colour:
I wish the ATW800/2 was also black...
I now have enough juice for my setup. :D
Next step, modify my STE case for the HDMI connector.
HigashiJun wrote: Wed May 13, 2026 10:01 am Next step, modify my STE case for the HDMI connector.
Could you remove the (redundant) RF modulator and then route a HDMI cable out through the existing TV out hole?
I guess STe cases are probably not rare and so cutting one is probably not like cutting a TT030 or MegaSTe case which IMO would only devalue it.
HigashiJun
alexh wrote: Wed May 13, 2026 10:48 am Could you remove the (redundant) RF modulator and then route a HDMI cable out through the existing TV out hole?
I was thinking about (I'm not so keen on cutting cases), but the HDMI connector is too close to the case to route a cable...
If the Monster bus connector was slightly further back, it would be feasible.
HigashiJun wrote: Wed May 13, 2026 11:24 am If the Monster bus connector was slightly further back, it would be feasible.
Definitely something to feedback to Alan for any future batches.
chronicthehedgehog
Post by chronicthehedgehog »
What about replacing the hdmi connector with a vertically mounted connector?
HigashiJun
chronicthehedgehog wrote: Wed May 13, 2026 8:05 pm What about replacing the hdmi connector with a vertically mounted connector?
How would I connect it ?
There is no room to plug anything between the HDMI connector and plastic case.
Or do you mean de-solder the horizontal one and replace it with a vertical one ?
chronicthehedgehog
HigashiJun wrote: Wed May 13, 2026 9:38 pm
Yes, sorry I meant de-solder and replace. It's not something I'd attempt but you have the soldering skills 8-)
assuming you can find something with the same footprint I suppose
HigashiJun
chronicthehedgehog wrote: Wed May 13, 2026 10:40 pm Yes, sorry I meant de-solder and replace. It's not something I'd attempt but you have the soldering skills 8-)
Thanks for this clarification.
Yes, I would have to find an HDMI connector with the same footprint, but I guess it's not so hard.
But the hassle would be then to de-solder the Tang Nano, de-solder its HDMI connector, solder the new one and then solder back the Tang Nano to the ATW800/2...
HigashiJun
Oh, and just another point.
A vertical HDMI connector could potentially hit the upper case with (and even without) and HDMI extender cable fitted in...
