White Screen on an A500
russellnash
Re: White Screen on an A500
Post by russellnash »
I replaced the Fat Anus socket. Removing the old socket was a lot of work. I decided to cut it away with the side cutters thinking I could heat the pins and pull them out easily. The plastic around the sides was brittle and broke off easily. The plastic base of the socket was not at all brittle and seemed to be stuck to the board with no space in between. I heated it up a bit, not hot enough to melt solder, until the edges curled up. That was hard work to remove.
The pins all broke off immediately when I pulled them, leaving 2 to 3mm left. Super. :D I managed to remove them, it was just much harder to grab them with the pliers and heat them up.
The new socket, although it looks shinier and is springier than the old one, made no difference. CAS is s stuck high and pins 32 and 33 of the CPU, that is A4 and A5 respectively, pulse much slower than the other address lines.
HigashiJun
Post by HigashiJun »
russellnash wrote: Thu Apr 30, 2026 7:04 am ...the Fat Anus socket.
:shock:
:lol: :lol: :lol:
Hellraiseruk
Post by Hellraiseruk »
That is now the new name for that chip, I can't go back to calling it Agnus now lol
JD
russellnash
I could say that I am dyslexic or that my keypad isn't working that well but I think it is perhaps a good description. 8-)
HigashiJun
We could also say that the chip's name is quite biased from the start...
Hellraiseruk
Can't wait for someone to start working with Fatter Anus or Obese Anus :)
I'm sorry, I may be in my 50s but my humour remains childish :)
JD
russellnash
Don't apologise. I didn't go to a posh school so we didn't learn Latin, but I always thought that Anus was Latin for Year. I also remember that when we did Science the planet Uranus was called Your Anus.
russellnash
HigashiJun wrote: Thu Apr 30, 2026 8:54 am We could also say that the chip's name is quite biased from the start...
Maybe Commodore just printed it wrong and decided to stick with the name as it was?
HigashiJun
russellnash wrote: Thu Apr 30, 2026 4:44 pm but I always thought that Anus was Latin for Year.
"Annus" is the Latin word for year, but "Anus" means exactly what it means...
Better not to confuse then "Annus Horribilis" with "Anus Horribilis".
BTW, check the meaning of the word "Uranian" and you'll see that it has a direct connotation with "Uranus"...
8-)
russellnash
I didn't know what a Uranian was. A typing error can certainly result in more interest in what you have written than would otherwise be the case.
I think in Millennium 2.2 the settlers of Uranus became Hydrogoids, but it has been a while.
