Converting HISOFT to 68K ASM "almost" works
Re: Converting HISOFT to 68K ASM "almost" works
mrbombermillzy wrote: Mon Feb 09, 2026 8:41 pm Looks like its using GEMDOS function $09 PRINT LINE which converts numerical data into character data.
Im sure the routine that does the conversion needs further study then... :coffee:
I dunno whats going on, about had enough for today :)
So far setting the year to 26 has come back as 28 and 42 now. Seems like those odd BCD type issues I had years ago.
mrbombermillzy
Post by mrbombermillzy »
exxos wrote: Mon Feb 09, 2026 8:45 pm
Yeah, I will have to come back to this. Are you still using the 2nd iteration of code?
Somewhere I recall seeing an addition of 20 to a register. If thats being used, perhaps remove the addition as it could be interpreting as '2' (which will cause the value 26+2=28...possibly.
mrbombermillzy wrote: Mon Feb 09, 2026 9:01 pm Yeah, I will have to come back to this. Are you still using the 2nd iteration of code?
Yeah, but ive been stripping things out.. So this is the current base code..
* Atari ST 68000 Assembly for Devpac
* Original working RTC read code (HiSoft BASIC compatible)
* + Added: set GEMDOS system date/time when no errors
* Updated now:
*   - Removed the "error flag" usage entirely
*   - Mask RTC reads to low byte with ANDI.W #$00FF (no +256 / -$FF00 tricks)
*   - No other behavioural changes intended (corruption messages still print)
        SECTION TEXT
START:
        jsr     GETRTCTIMEDATE
        clr.w   -(sp)
        trap    #1
* BusyWait - returns d0=0 ok, d0=1 timeout
BUSYWAIT:
        movem.l d1/a0,-(sp)
        move.l  #10000,d1
.loop:
        move.w  #$FF0A,(RTC_ADDR)
        move.w  (RTC_DATA),d0
        andi.w  #$00FF,d0       ; <-- mask to low byte
        btst    #7,d0           ; UIP bit
        beq.s   .ok
        subq.l  #1,d1
        bne.s   .loop
        moveq   #1,d0
        bra.s   .exit
.ok:
        moveq   #0,d0
.exit:
        movem.l (sp)+,d1/a0
        rts
GETRTCTIMEDATE:
        movem.l d0-d7/a0-a1,-(sp)
        jsr     BUSYWAIT
        tst.w   d0
        beq.s   .notimeout
        pea     MSG_TIMEOUT(PC)
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
        bra     .exit
.notimeout:
* Seconds (reg 0)
        move.w  #$FF00,(RTC_ADDR)
        move.w  d0,d6           ; S%
        jsr     BUSYWAIT
* Minutes (reg 2)
        move.w  #$FF02,(RTC_ADDR)
        move.w  d0,d5           ; M%
        jsr     BUSYWAIT
* Hours (reg 4)
        move.w  #$FF04,(RTC_ADDR)
        cmpi.w  #128,d0
        blo.s   .no_pm
        subi.w  #128,d0         ; clear PM bit
.no_pm:
        move.w  d0,d4           ; H%
* Time validity (messages only; no error flag)
        cmpi.w  #24,d4
        bhi.s   .timecorr
        cmpi.w  #60,d5
        bhi.s   .timecorr
        cmpi.w  #60,d6
        bhi.s   .timecorr
        bra.s   .timeok
.timecorr:
        pea     MSG_CORRUPTED(PC)
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
.timeok:
* Weekday (reg 6)
        move.w  #$FF06,(RTC_ADDR)
        move.w  d0,d3           ; DY%
* Day (reg 7)
        move.w  #$FF07,(RTC_ADDR)
        move.w  d0,d2           ; DATE%
* Month (reg 8)
        move.w  #$FF08,(RTC_ADDR)
        move.w  d0,d1           ; MTH%
* Year (reg 9)
        move.w  #$FF09,(RTC_ADDR)
        move.w  d0,d7           ; save YR in d7
* Check date validity (messages only; no error flag)
        cmpi.w  #7,d3
        bhi.s   .datecorr
        cmpi.w  #32,d2
        bhi.s   .datecorr
        cmpi.w  #12,d1
        bhi.s   .datecorr
        bra.s   .dateok
.datecorr:
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
.dateok:
* DM bit check (binary mode) (message only; no error flag)
        jsr     BUSYWAIT
        move.w  #$FF0B,(RTC_ADDR)
        btst    #2,d0           ; DM=1 (binary)
        bne.s   .dmok
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
.dmok:
* --------- set GEMDOS system date/time ----------
        jsr     SET_SYSTEM_TIME
.print_only:
* Print: H M S DATE MTH YEAR
        move.w  d4,d0
        jsr     PRINT_NUM
        move.w  d5,d0
        jsr     PRINT_NUM
        move.w  d6,d0
        jsr     PRINT_NUM
        move.w  d2,d0
        jsr     PRINT_NUM
        move.w  d1,d0
        jsr     PRINT_NUM
        move.w  d7,d0           ; year from d7 (00-99)
        jsr     PRINT_NUM
.exit:
        movem.l (sp)+,d0-d7/a0-a1
        rts
* SET_SYSTEM_TIME
* Uses: d4=hour d5=min d6=sec d2=day d1=month d7=year(00-99)
* Assumes RTC year is 2000-2099 -> years since 1980 = 20 + year
* GEMDOS:
*   Tsetdate (0x2B): packed date = ((year-1980)<<9) | (month<<5) | day
*   Tsettime (0x2D): packed time = (hour<<11) | (min<<5) | (sec>>1)
* Note: 68000 immediate shifts only allow #1..#8, so we split <<9 and <<11.
SET_SYSTEM_TIME:
        movem.l d1-d3,-(sp)
* ---- Pack date into d2.w ----
        move.w  d2,d3           ; save DAY into d3
        move.w  d7,d2           ; year 00-99
        andi.w  #$00FF,d2       ; safety mask
        addi.w  #20,d2          ; years since 1980 (assumes 2000-2099)
        lsl.w   #8,d2           ; <<9 (part 1)
        lsl.w   #1,d2           ; <<9 (part 2)
        andi.w  #$00FF,d1       ; safety mask month
        lsl.w   #5,d1           ; month<<5  (d1 saved by movem)
        or.w    d1,d2
        andi.w  #$00FF,d3       ; safety mask day
        or.w    d3,d2           ; OR in day
        move.w  d2,-(sp)
        move.w  #$2B,-(sp)      ; Tsetdate
        trap    #1
        addq.l  #4,sp
* ---- Pack time into d3.w ----
        move.w  d4,d3           ; hour
        lsl.w   #8,d3           ; <<11 (part 1)
        lsl.w   #3,d3           ; <<11 (part 2)
        move.w  d5,d1           ; min
        lsl.w   #5,d1           ; min<<5
        or.w    d1,d3
        move.w  d6,d1           ; sec
        lsr.w   #1,d1           ; sec>>1
        or.w    d1,d3
        move.w  d3,-(sp)
        move.w  #$2D,-(sp)      ; Tsettime
        trap    #1
        addq.l  #4,sp
        movem.l (sp)+,d1-d3
        rts
* PRINT_NUM: prints 0-99 as decimal string + CRLF (no leading zero)
PRINT_NUM:
        movem.l d1/a1,-(sp)
        lea     BUFFER(PC),a1
        cmpi.w  #10,d0
        bcs.s   .one
        clr.l   d1              ; clear high word for clean dividend
        move.w  d0,d1
        divu.w  #10,d1
        swap    d1              ; remainder in low
        addi.b  #'0',d1
        move.b  d1,1(a1)        ; units
        swap    d1              ; quotient in low
        addi.b  #'0',d1
        move.b  d1,(a1)         ; tens
        moveq   #2,d1
        bra.s   .out
.one:
        addi.b  #'0',d0
        move.b  d0,(a1)
        moveq   #1,d1
.out:
        clr.b   (a1,d1.w)
        pea     (a1)
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
        pea     CRLF(PC)
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
        movem.l (sp)+,d1/a1
        rts
        SECTION DATA
RTC_ADDR        EQU     $FF89F0
RTC_DATA        EQU     $FF89F2
MSG_TIMEOUT     DC.B    'RTC TIME OUT!',13,10,0
MSG_CORRUPTED   DC.B    'RTC TIME IS CORRUPTED',13,10,0
CRLF            DC.B    13,10,0
        SECTION BSS
BUFFER          DS.B    10
        END
I tried setting it to 18 early on, made no odds.
Tried a hardwired clock set and that fails same way also.
* Bare-bones sanity test:
*   Hardwire date = 09/02/2026 and time = 00:00:00
*   Calls GEMDOS Tsetdate/Tsettime only (no RTC access at all)
* Date packing (Tsetdate, opcode $2B):
*   bits 0-4  = day   (1-31)
*   bits 5-8  = month (1-12)
*   bits 9-15 = year since 1980
* For 09/02/2026:
*   year since 1980 = 2026-1980 = 46
*   packed_date = (46<<9) | (2<<5) | 9
* Time packing (Tsettime, opcode $2D):
*   bits 0-4  = seconds/2
*   bits 5-10 = minutes
*   bits 11-15= hours
* For 00:00:00 => packed_time = 0
        SECTION TEXT
START:
        jsr     SET_KNOWN_DATETIME
        clr.w   -(sp)           ; Pterm0
        trap    #1
* SET_KNOWN_DATETIME
* Sets system date/time to 09/02/2026 00:00:00
SET_KNOWN_DATETIME:
        movem.l d0-d2,-(sp)
* ---- Build packed date in d0.w ----
* day=9, month=2, year_since_1980=46
        move.w  #46,d0          ; year_since_1980
        lsl.w   #8,d0           ; <<9 (68000 shift immed max is 8)
        lsl.w   #1,d0
        move.w  #2,d1           ; month
        or.w    d1,d0
        or.w    #9,d0           ; day
* Call GEMDOS Tsetdate(date)
        move.w  d0,-(sp)
        move.w  #$2B,-(sp)
        trap    #1
        addq.l  #4,sp
* ---- Build packed time in d0.w ----
* 00:00:00 => 0
        clr.w   d0
* Call GEMDOS Tsettime(time)
        move.w  d0,-(sp)
        move.w  #$2D,-(sp)
        trap    #1
        addq.l  #4,sp
        movem.l (sp)+,d0-d2
        rts
        END
I took out flashyclock.. as well. But wonder if the keyboard RTC is getting in the way somehow :shrug:
That return value nails it:
Gettime returned 00490000
upper word (date) = 0049
lower word (time) = 0000
Decode 0049 as a packed GEMDOS-style date:
day = 0x0049 & 0x1F = 9
month= (0x0049 >> 5) & 0x0F = 2
year = (0x0049 >> 9) & 0x7F = 0 → 1980
So XBIOS Gettime is giving you 09/02/1980, exactly matching CP.
Why your year won’t set via XBIOS on your machine
On STs, XBIOS Settime(22) / Gettime(23) talk to the IKBD (keyboard controller) clock (“hardware clock” in TOS docs). That IKBD clock has well-known limitations/bugs around the year, and many setups effectively behave as if the year is fixed at 0 (=1980) or can’t be set reliably. This matches your observation perfectly.
So:
GEMDOS Tsetdate/Tsettime works (you proved it: 5C49/0000)
XBIOS Settime does NOT accept/store the year on your current configuration (it returns year=0)
Control Panel is showing the IKBD/XBIOS clock, not GEMDOS.
That also explains why removing your separate RTC chip changed behaviour earlier: CP is fundamentally tied to the “hardware clock” path (IKBD/XBIOS), and GEMDOS is a separate software-maintained system clock unless TOS syncs them.
Bottom line
Your GEMDOS code is correct.
CP is reading XBIOS Gettime, which on your setup is effectively stuck at year 1980 (year field 0).
To make CP show 2026, you need a tool/patch that fixes the IKBD/XBIOS year handling, or a CP that displays GEMDOS time instead.
There are existing “Y2K/Y2K+” style patches/utilities that intercept XBIOS time calls and apply an offset so modern years display correctly (e.g., fixes that map 2024↔1992 internally).
mrbombermillzy
My next step would be to break out the debugger and work back (if its incorrect) from the final number - stored as a string - in a1 to check the string is correct values before it goes into the GEMDOS 'set date' funtion ($2b). Just above the rts in PRINT_NUM function would be a good place to look at the location 'BUFFER' or the a1 stream working back from its current position.
Also, Im not sure about all that rotating.for the 'set date' function. Very hard to read. Simplify by changing:
        or.w    d1,d2
        move.w  d2,-(sp)
        trap    #1
        addq.l  #4,sp
to:
        move.w  #%0101110001001001,-(sp)
        trap    #1
        addq.l  #4,sp
Ive (hopefully correctly) calculated the packed date to give 9th Feb 2026. Try this 'hardwired' date with this changed and see what happens.
@mrbombermillzy we crossed streams a bit..
https://www.exxosforum.co.uk/forum/view ... 90#p139581
Its a TOS issue it seems..
mrbombermillzy
I see. I will let Anders take the baton then. :D
agranlund
Post by agranlund »
mrbombermillzy wrote: Mon Feb 09, 2026 11:28 pm I see. I will let Anders take the baton then. :D
No, no, i dont want a baton :D
Just posted some ancient code that may or may not be relevant in case it would be useful to someone :)
Oh, and not that it matters in this case, but the STe ROM sets the time differently to the original ST, giving a different time when read back.
Well that didn't work then, it just loads and then just resets the machine :(
; DS12885 RTC driver for agranlund/rtc framework (CORE.S)
; GenST Macro Assembler compatible
DEV_BASE_ADDR	EQU	$FF89F0
DEV_WRITE_ADDR	EQU	$FF89F0
DEV_READ_ADDR	EQU	$FF89F2
DEV_NVRAM_SIZE	EQU	$80
DEV_CONF4	EQU	0
DEV_CONF5	EQU	0
DEV_CONF6	EQU	0
DEV_CONF7	EQU	0
	include "CORE.S"
	SECTION TEXT
; Low-level helpers
rtc_read:			; d0.w = reg, returns d0.w = value (0-255)
	move.w	d0,(RTC_ADDR)
	andi.w	#$00FF,d0
	rts
rtc_write:			; d0.w = reg, d1.w = value (low byte used)
	move.w	d1,(RTC_DATA)
	rts
devInit:				; d0.l = return status, 0=failed, 1=ok
	moveq	#1,d0
	rts
;devGetTime:			; d0.l = return in TOS format (date<<16 | time)
devGetTime:
	movem.l	d1-d7,-(sp)
	; read RTC fields (binary assumed)
	moveq	#0,d0
	bsr	rtc_read
	move.w	d0,d6			; sec
	moveq	#2,d0
	bsr	rtc_read
	move.w	d0,d5			; min
	moveq	#4,d0
	bsr	rtc_read
	move.w	d0,d4			; hour
	moveq	#7,d0
	bsr	rtc_read
	move.w	d0,d2			; day
	moveq	#8,d0
	bsr	rtc_read
	move.w	d0,d1			; month
	moveq	#9,d0
	bsr	rtc_read
	move.w	d0,d7			; year 00-99
	; pack date
	addi.w	#20,d7			; year_since_1980 = 20 + year (assume 2000-2099)
	move.w	d7,d3
	lsl.w	#8,d3
	lsl.w	#1,d3			; <<9 total
	or.w	d1,d3
	or.w	d2,d3			; day
	; pack time
	move.w	d4,d0			; hour
	lsl.w	#8,d0
	lsl.w	#3,d0			; <<11 total
	lsl.w	#5,d5			; min<<5
	or.w	d5,d0
	lsr.w	#1,d6			; sec>>1
	or.w	d6,d0
	; combine long
	swap	d3
	move.w	d0,d3
	move.l	d3,d0
	movem.l	(sp)+,d1-d7
	rts
;devSetTime:			; d0.l = input in TOS format (date<<16 | time)
devSetTime:
	movem.l	d1-d7,-(sp)
	; split input
	move.l	d0,d3
	swap	d3				; d3.w = packed date
	move.w	d0,d4			; d4.w = packed time
	; unpack date
	move.w	d3,d7
	lsr.w	#8,d7
	lsr.w	#1,d7			; >>9 total
	subi.w	#20,d7			; back to 00-99
	move.w	d3,d1
	lsr.w	#5,d1
	andi.w	#$000F,d1		; month
	move.w	d3,d2
	andi.w	#$001F,d2		; day
	; unpack time
	move.w	d4,d6
	andi.w	#$001F,d6
	lsl.w	#1,d6			; sec
	move.w	d4,d5
	lsr.w	#5,d5
	andi.w	#$003F,d5		; min
	lsr.w	#8,d4
	lsr.w	#3,d4			; hour >>11
	; freeze updates (SET=1)
	moveq	#$0B,d0
	bsr	rtc_read
	ori.w	#$0080,d0
	move.w	d0,d1
	moveq	#$0B,d0
	bsr	rtc_write
	; write RTC regs
	moveq	#0,d0
	move.w	d6,d1
	bsr	rtc_write
	moveq	#2,d0
	move.w	d5,d1
	bsr	rtc_write
	moveq	#4,d0
	move.w	d4,d1
	bsr	rtc_write
	moveq	#7,d0
	move.w	d2,d1
	bsr	rtc_write
	moveq	#8,d0
	move.w	d1,d1			; month still in d1
	bsr	rtc_write
	moveq	#9,d0
	move.w	d7,d1
	bsr	rtc_write
	; unfreeze (SET=0)
	moveq	#$0B,d0
	bsr	rtc_read
	andi.w	#$007F,d0
	move.w	d0,d1
	moveq	#$0B,d0
	bsr	rtc_write
	movem.l	(sp)+,d1-d7
	rts
;devReadNVram:		; a0 = buffer, d0 = start, d1 = length (stub)
devReadNVram:
	rts
;devWriteNVram:		; a0 = buffer, d0 = start, d1 = length (stub)
devWriteNVram:
	rts
