TF1260 Fan header voltage problem
rabidgerry
Re: TF1260 Fan header voltage problem
Post by rabidgerry »
It looks like there is something in what you guy's are saying @PhilC and @rubber_jonnie .
So baring in mind I am not a skilled guy who knows the specifics about electronics etc. But I've some basic understanding.
Hear goes. So in the photo, I have worked out the soldered hole that has the 3 different coloured lines coming out of it is the negative/gnd for the fan header. So establishing that, I used my multi-meter to test the next component inline with it which is the little black resistor/cap (not sure which) you see to the right of the soldered hole.
So from the negative fan hole to the black component on the right, the yellow line represents a good continuity between it and point 3 from the multi-meter. The pink line represents a little bit of continuity between it and point 2, not great. Then the red line, no continuity at all between the fan negative and point 1. So then I worked out that there is good continuity between point 1 and other gnd's such as the ground on the jtag header.
So this must be negative/gnd in which case as you gents suggest the fan header gnd isn't connecting so well to that little black component which seems to be a gnd.
Do I need to try and solder better points 1 and 2 to the little black component? Thank you for any guidance and apologies for my basic and lack of knowledge.
rabidgerry wrote: Fri Jan 30, 2026 10:49 am It looks like there is something in what you guy's are saying @PhilC and @rubber_jonnie .
So that 3 legged SMD component looks like it might be a Mosfet, though I'm not 100% sure and it might be there to drive the fan. Before you go and do any soldering use your multimeter to check from the top of the pin to the pad, or if yo can somewhere on a nearby trace that connects to it to be 100% sure that connectivity is there. Simply testing for continuity like that may well give odd results if you're trying to do it a cross a transistor/mosfet.
rabidgerry
rubber_jonnie wrote: Fri Jan 30, 2026 11:15 am
So there isn't actually a pin soldered in there at the moment. I just was lazy and didn't suck the solder out. Do you think I should try and solder a bit more at that mosfet? The solder currently in the hole connects perfectly to the trace which leads to the first pad on the right that connects to the mosfet.
rabidgerry wrote: Mon Feb 02, 2026 11:55 am
I meant the pins of the Mosfet to ensure that there was continuity from the 3 pins of the Mosfet to the pads it's soldered to, not the pins of the fan header.
If continuity is fine from the top of the leg of the Mosfet to the pad on the board there is no need to add more solder.
likely the transistor isn't turning on fully. i think 9v is all you get with the base resistor
EDIT: Also you will likely have a 1.4 volt drop across the transistor regardless. Its a NPN so its 2 x 0.7V diodes back to back effectively. So with a 11.5V rail you'll see 10 best case.
rabidgerry
Can anyone else confirm what they get of the rail?
I realise it's perhaps unconventional and I'm fully responsible for busting my TF1260, but I tried this (see pic) and I get 12v no problem and any fan I tried work as you would expect. Is the transistor a necessary requirement? I have seen some picture of TF1260 cards that do not have it.
rabidgerry wrote: Thu Feb 05, 2026 1:07 pm Can anyone else confirm what they get of the rail?
The transistor is for software switching. just remove it and short to ground if you want it on all the time.
Question i have is why not use the floppy connector or something if you want 12V all the time. its much better to use that than drawing too much on 12v from the cpu connector. its possibly you've got a resistance/voltage drop at the cpu connector too
terriblefire wrote: Fri Feb 06, 2026 12:07 pm Question i have is why not use the floppy connector or something if you want 12V all the time. its much better to use that than drawing too much on 12v from the cpu connector. its possibly you've got a resistance/voltage drop at the cpu connector too
It was suggested earlier in the thread as it's what I did for my PiStorm in my A1200, the FDD connector is much better suited for 12v.
