SpeedyTT, black screen of death !!!! HELP
Re: SpeedyTT, black screen of death !!!! HELP
here is the results of my testing, the red X are the continuity fail (red number are the test #, not the pin #)
Anyone know where is R950 is on the board ? I cannot find it.
- HigashiJun
Ouch, that's pretty bad...
Now you have to bodge wire all the missing connections.
- frank.lukas
You need a professional electric vacuum desoldering pump and experience for this kind of work. It's a multilayer circuit board and therefore quite delicate. If in doubt, clip off the IC pins and desolder them individually using tweezers.
A manual desoldering pump is completely unsuitable.
Atarian Computing
You have a later revision TT that never had the schematics published by Atari. The only schematics available are for the PGA revision so there is bound to be minor differences.zfrenchy wrote: Thu Jan 08, 2026 2:58 am Anyone know where is R950 is on the board ? I cannot find it.
I have a Hakko 470frank.lukas wrote: Thu Jan 08, 2026 6:42 am You need a professional electric vacuum desoldering pump and experience for this kind of work. It's a multilayer circuit board and therefore quite delicate. If in doubt, clip off the IC pins and desolder them individually using tweezers.
Ok. ThxAtarian Computing wrote: Thu Jan 08, 2026 6:47 amYou have a later revision TT that never had the schematics published by Atari. The only schematics available are for the PGA revision so there is bound to be minor differences.zfrenchy wrote: Thu Jan 08, 2026 2:58 am Anyone know where is R950 is on the board ? I cannot find it.
Hi zfrenchy,zfrenchy wrote: Thu Jan 08, 2026 2:58 am here is the results of my testing, the red X are the continuity fail (red number are the test #, not the pin #)
it is best to re-solder all pins of the GALs and the 74LS74.
Yes, indeed. Look at the attached picture.Anyone know where is R950 is on the board ? I cannot find it.
In some boards, R950 has a value of 33 ohms.
Best regards
Robert
Can you shot to me another photo of you board top silkscreen including the region of the CPU ?12-MHz wrote: Fri Jan 09, 2026 12:49 pmHi zfrenchy,zfrenchy wrote: Thu Jan 08, 2026 2:58 am here is the results of my testing, the red X are the continuity fail (red number are the test #, not the pin #)
Best regards
Robert
It will be handy to see the traces whitout the component.
ALL FIXED, hoping not coming back here when I will install the SpeedyTT, Storm and LighningVME.
At the end, it was only some point to resolder, and a new budge wire between U11 pin 17 and U112 pin 2, no component damaged so far, will see after a while.
Glad you got it working again. Always a nervous time when we do work on these old systems and they stop working.
Let us know how you get on with the SpeedyTT, Storm and LightningVME.
