Sounds like a plan, but unfortunately to fit your PokeyMax you're going to have to pull the case off, so definitely a good time to work on that crack.PhilC wrote: 27 Jan 2026 17:19 Thanks @rubber_jonnie. I have a big crack in the top case of the 800, so I take the case off as little as possible.
I should probably get round to stabilising the crack when I fit the Pokeymax.
The Naked Atari 800
Re: The Naked Atari 800
OK a little more clock shenanigans tonight.
I lifted pin 16 of the GTIA which is where the colourburst clock comes into it. No colourburst clock and everything is monochrome, all good.
I then gave the clock module an ATTiny that had the PAL master clock and PAL colourburst clock programmed on clocks 0 and 1 of the Si5351 board and hooked clock 1 up pin 16 of the GTIA.
Well it all worked a treat so the clock module is now doing double duty as the master clock at 3.546894 Mhz and the colourburst clock at 4.433618 Mhz :) You can see all the hook up points here:
GTIA hookup on pin 16 is here, the other end of the green cliplead:
Colour looks great:
Clocks measure just right:
And the whole ensemble looks spot on :)
It's all standalone and powered direct from the Atari 800.
I have to say this project has worked out far better than I could ever have hoped for. As a test I'm going to see if this setup will work in one of my 2600's doing the job of the same crystals.
I'm fairly sure it would work in most scenarios where you can't find a crystal.
:girldance: :girldance: :girldance:
Colour looks great:
:cheer: :dualthumbup: :yay2:
Well, the Naked Atari 800 is no longer Naked!!!
It's wearing underwear :)
Currently just running the master clock with the Si5351 but I have a plan to add the colourburst clock now that I know where it's supposed to connect to on the CPU board.
I should be able to simply lift a single resistor on the CPU board to disconnect the on board colourburst clock and then solder in a wire to the trace that connects to pin 16 of the GTIA and take both clocks from the Si5351.
I just got this:PhilC wrote: 27 Jan 2026 12:11 I've got a Pokeymax that I was thinking of putting in to my 800 but haven't looked how hard it is or where the pokey actually is.
I was struggling to get another PokeyMax so I thought I'd give AcidStereo a try. It will likely be going into my own 800.
@rubber_jonnie I shall be watching, ready for fitting mine then.
It looks to all intents and purposes very like the PokeyMax, soo I suspect it will be a similar experience. Not sure if my good 800 (Not the one on this thread) has a socketed Pokey, I can't recall.
Either way I think it'll work out just fine. I'll run a separate thread on it when I get round to it.
ijor
I don't have any personal experience with that board, but seems it is not exactly the same. This one requires the original Pokey to be installed. That's why it has a pass through socket. Pokeymax, does not.
http://pasti.fxatari.com
True but does retain the original Pokey just for SIO and keyboard functions and does include 2 Pokey/4 Covox in the FPGA, so the end result is really quite similar to PokeyMax, just done in a slightly different manner.ijor wrote: 02 Feb 2026 23:07I don't have any personal experience with that board, but seems it is not exactly the same. This one requires the original Pokey to be installed. That's why it has a pass through socket. Pokeymax, does not.
Unfortunately I've struggled to find PokeyMax of late (I already have 2, one in an XL the other in an XE) and prices have gone up, so I'll happily try the alternative that is available. It's frustrating as PokeyMax is a known quantity to me, but what can you do?
ijor
Mark (PokeyMax developer) is just going to release the first batch of PokeyMax's last version. I understand he already ordered the boards from the manufacturer, but he might still have a few unsold ones, if you are interested:rubber_jonnie wrote: 02 Feb 2026 23:48 Unfortunately I've struggled to find PokeyMax of late (I already have 2, one in an XL the other in an XE) and prices have gone up, so I'll happily try the alternative that is available. It's frustrating as PokeyMax is a known quantity to me, but what can you do?
https://forums.atariage.com/topic/38658 ... er-thread/
Users browsing this forum: Ahrefs [bot], CCBot, Icky, Qwantbot and 47 guests
