Booster V4sm problem
zfrenchy
Re: Booster V4sm problem
Post by zfrenchy »
I am back ... sorry, LOL
I have a HP1663CS logic analyzer and can provide timing when the STE is not booting.
Where should I connect the CLOCK input pin of the analyzer ?
- on CLK8 from pin 3 of the MCU (U400), pin 15 68000 (U100) ?
- or somewhere on the booster ?
I have connected:
- analyzer input #0 to pin 4 of U405
- analyzer input #1 to end of wire on the booster
- analyzer input #2 to pin 1 of the GAL on the booster
Let me know if other pin input will be nice to have.
Note:
I am using these tutorial to learn the logic analyzer
https://www.youtube.com/watch?v=6w5w3ez ... WM8vCCUzEG
https://www.youtube.com/watch?v=B64jH28 ... EG&index=2
I cant help with the LA stuff.. But not sure if your aware, there a 16mhz clock somewhere to the right of the shifter.. You can actually try soldering the 32mhz there for a test.
Have you tried the original PSU? Your likely not getting very good regulation looking by the long PSU cable you have..
zfrenchy
Post by zfrenchy »
all test where made with a Meanwell RD-50N-R5 and an the original ATARI STE PSU, with the same results, white screen, no booting when the STE is powered for a 'long' time.
I guess I should power up one time a day, or take longer coffee breaks !!!!
LOL
zfrenchy
Post by zfrenchy »
exxos wrote: Sun Feb 15, 2026 11:21 pm I cant help with the LA stuff.. But not sure if your aware, there a 16mhz clock somewhere to the right of the shifter.. You can actually try soldering the 32mhz there for a test.
do you mean GST SHIFTER pin 52 (GST MCU pin 2) ?
I cannot found on the PCB, except on the IC packages, but I don't want solder on these really tiny pads.
Screen Shot 02-15-26 at 03.54 PM.PNG (78.98 KiB) Viewed 1656 times
This is where I took 16mhz off.. Must be a via there.. You would have to check which pin that goes to on the shifter yourself.. I think it was one near the top right somewhere..
zfrenchy
Post by zfrenchy »
exxos wrote: Mon Feb 16, 2026 7:56 pm This is where I took 16mhz off.. Must be a via there.. You would have to check which pin that goes to on the shifter yourself.. I think it was one near the top right somewhere..
confirmed, pin 53, top right minus one pin
