Booster V4sm problem
Re: Booster V4sm problem
You still haven't answered the previous questions https://www.exxosforum.co.uk/forum/view ... 81#p137001
Also the 1712 shifter is know to cause problems also.
zfrenchy
Post by zfrenchy »
exxos wrote: Sat Jan 17, 2026 11:49 pm You still haven't answered the previous questions https://www.exxosforum.co.uk/forum/view ... 81#p137001
Not sure what specific question are you talking about, but here is my answers:
- yes U406 is the right 74F257
- yes the wire was re-routed above the PCB board, and following the black wire path in the installation tuto
- yes the reset capacitor got an increase value (piggy back C100 10MF with 22MF)
- the issue happen only while in 32Mhz mode, 8 Mhz mode has no issue booting
I received the DMA-Fix little board (thank you), should I install it ?
You can try it but I've never known it to cause not booting.. Possibe yes..
Does 32MHz start after pressing the reset switch?
Have you tried without the ROM wire?
Changed RP100 is 1.2k?
zfrenchy wrote: Sat Jan 17, 2026 10:19 pm I replaced the memory with this
https://www.ebay.com/itm/146732336055
and run the wire exactly as the tuto said
But still have issue with the booting
Just a small admin note, with ebay listings it's better to just get a screen shot and post that rather than a link to a listing which could dissappear at some point.
As for your issue a white screen is usually an indicator of a ROM issue. Have you also upgraded the ROM? If so you should make sure it's seated and the booster connection is good.
zfrenchy
Post by zfrenchy »
exxos wrote: Sun Jan 18, 2026 5:49 am You can try it but I've never known it to cause not booting.. Possibe yes..
No, the 32Mhz mode do not start when reset
yes, P100 is 1.2k
zfrenchy
Post by zfrenchy »
rubber_jonnie wrote: Sun Jan 18, 2026 8:28 am
yes, I have the FastROM Dual TOS from Exxos installed
zfrenchy
Post by zfrenchy »
I made 3 videos posted on youtube
https://youtu.be/SGjm2KsJk6s
Booting the STE at 9:18am: no issue
hard reset: no booting, black screen
OFF/ON: no booting, black screen
10 minutes later ...
https://youtu.be/Tuv-apnZ0hs
Booting at 9:30am: no issue
hard reset: no issue
soft reset: no issue
OFF/ON: no issue
https://youtu.be/vir1co3xlWk
Booting at 9:43am: no issue
OFF, 8Mhz mode, ON: no issue
OFF, 32Mhz mode, ON: no booting, black screen
soft reset: no booting, black screen
I don't understand ?!
May be a faulty capacitor ? I did recapped all of it.
I only know of shifter problems on the STE. The 1712 have issues, the original doesn't. So thats my only suggestion to try swapping the shifter for the original as its less problematic. Normally the video goes nuts first, later RAM issues. That's all I can suggest as I have not seen or documented any other faults on the STE yet.
zfrenchy
Post by zfrenchy »
I will install the DMA Fix board, and see ...
zfrenchy
Post by zfrenchy »
I installed the DMA-Fix board, same issue, black screen sometime on 32Mhz mode, never on 8Mhz mode.
Then I removed the DMA-Fix board ...
Now I still have the same black screen issue on 32Mhz mode PLUS The TOS logo and RAM test never show up, whatever mode I am one or the way to reset the STE.
I don't care about the Atari logo and memory test not showing, make the boot faster, everything is working, so far in 8Mhz mode.
I removed the Boost board to check any issue with the PGA pin, nothing obvious there, did the same with the DualTOS board, nothing.
