Donix H5 C5B build
All related information and builds for the 2025 edition.
donix
Re: Donix H5 C5B build
Post by donix »
Tried to do some scoping on the RESET, AS and A* pins according to the troubleshooting guide and full disclaimer: I am still a bit new to using a scope but I think I did manage to get it to correctly trigger on reset - it does capture the monitored pins after the expected 1ish second delay. However, !AS and A* pins remain constantly high and never go low.
On a whim I checked the HALT pin since I remembered that being eternally high on an earlier occasion and caught it doing this:
I can reproduce this and the shape remain the same but the frequency can vary a bit. The bus pull-up on HALT checks out at 1K. Following the schematic it looks to me as the only thing connecting to HALT is U14? Could U14 be dodgy or is there something else on the halt line that I missed?
Normal when the cpu is crashing. You need to do all the tests and not get sidetracked onto other things.
donix
Post by donix »
exxos wrote: Wed Nov 26, 2025 12:21 am Normal when the cpu is crashing. You need to do all the tests and not get sidetracked onto other things.
Thanks @exxos. It is easy to start looking for irregularities at random. The reason for taking stabs in the dark that I didn't really think that I could advance further in the guide. I did follow all the steps in the guide up to and including the first part of the first bus cycle test and on that one I found that neither address line nor !AS ever go low and in that situation I guess that there is no chance of the rest ever working.
Today i got the AT27C4096:s which brought no improvement although they do pop into the socket with a much more distinctive feel. I beeped out all the pins on the CPU PLCC and ROM sockets just to make sure that all are connected and they were. Then I made one more stab in the dark with swapping in the DIP 68K that is intended for my ST booster and lo and behold: The ST starts. :shock: :D
The H5 will now work with the DIP 68kP16 as well as with the original PLCC 68k that came out of the STE but it will not with the PLCC 68HC000ET16 that I have available, which was tested in the STE and the twin if which seems to work in the STE right now. But I guess it might be bad somehow...
What a relief though! That was quite a few hours spent down the rabbit hole. Now on to fitting more stuff to the board!
:bravo: :girldance:
Maybe your CPU has a slightly bent pin or something ? Its normally silly things like that which cause all the trouble. Its why I suggested the Atmel ROMs as the Eproms don't tend to contact very well anyway.
Well done!
donix
Post by donix »
exxos wrote: Thu Nov 27, 2025 9:06 pm :bravo: :girldance:
Well done!
Thanks! It's nice to get somewhere! The CPU pins look good under magnification but it does maybe slide in a tad too effortlessly.
donix
Post by donix »
I finally had some time to go to continue working on the H5 and it is progressing.
Tested working now is all 4MB of RAM, dualTOS operation, ACSI with ACSI2STM, and blitter but now I seem to have gotten stuck on another issue. I have no sound. Initially I thought that the sound amp chip had not survived desoldering by hot air so I replaced it with a new one but that did not help. Further testing shows that there is actually no output from the YM2149 (which works fine in another ST) on pins 3,4 and 38 when playing sounds. There is activity on the BDIR and BC1 pins although perhaps not as much as on the reference ST where I have sound. The glue sound decoder jumper is closed and there is some activity there as well.
Any idea as to what is going on? Is there a jumper that I have missed?
Jumpers next to midi synth connector..
Though I can't look what they were actually for until tomorrow.. Might be best check the schmatic..
Return to “H5 C5B USER BUILDS”
