The Family Computer has arrived!!!
Re: The Family Computer has arrived!!!
I'll believe it when you see it! :-)
stephen_usher wrote: Fri Nov 21, 2025 1:51 pm I'll believe it when you see it! :-)
Me too!!!
Woo hoo it's here!!!
Leaving it to reach a localised temp before plugging it in :)
HigashiJun
Post by HigashiJun »
:girldance:
HigashiJun
Ah, those Chinese friends, even unable to correctly copy something...
Check the Japanese "Kana" on your cart (above EVERGENESIS-N8) and you'll understand:
Real N8 cart
Real N8 cart
The "Kana" on the real cart mean EBA- DORAIBU N8 (= EVERDRIVE N8)
while on yours, it could be something like EHA- TOFUIFU N8
:lol:
Just hope it will work fine.
HigashiJun wrote: Fri Nov 21, 2025 11:06 pm Ah, those Chinese friends, even unable to correctly copy something...
:lol:
I wouldn't be surprised if it's a deliberate mistakes tbh. Works just fine and is actually very well made.
HigashiJun
rubber_jonnie wrote: Sat Nov 22, 2025 8:32 am I wouldn't be surprised if it's a deliberate mistakes tbh. Works just fine and is actually very well made.
Nice to hear that !
So you can fully enjoy your new toy now.
8-)
BTW, are you pleased with the image quality you're getting from the AV mod ?
Overall it's very good as it goes with one exception.
When there are large areas of blue on screen there are prominent jailbars, but everything else is actually really good.
I did fit a cap across pins 20/22 of the ppu and that helped a lot but there are still some.
TBH it's not bad enough for me to to worry about it too much but I may increase the value to see if it helps reduce it some more.
Overall I'd recommend it as an upgrade.
HigashiJun
rubber_jonnie wrote: Sat Nov 22, 2025 11:14 am Overall I'd recommend it as an upgrade.
:dualthumbup:
Thanks for the feedback !
HigashiJun wrote: Sat Nov 22, 2025 12:58 pm
:dualthumbup:
What's also great about that upgrade is that it comes with a USB to barrel jack poer cable, so if you want to use just a normal PSU you can.
