Hi,
Time for an update.
Before I will progress on the SW side (MINT & MagiC), I fine-tuned the system a bit on the HW side:
* Fiddled two little switches to the back of my case, to have reset and NMI switches. The case has a lot of „holes“ for ventilation. Filed two of them a bit bigger and mounted the switches
- IMG_5023.jpeg (520.38 KiB) Viewed 1647 times
* Managed to source a W32i card (ET4W32-5, only 1MB and interleave is not working). But this card is pretty fast compared to the non-accelerated cards (like AX).
- IMG_5025.jpeg (318.26 KiB) Viewed 1647 times
* Had to tune the BIB files, so that my modern 16:9 Philips screen likes the signal. 1280x720x8 looks pretty good and fits well to the 16:9 monitor. Although I see some artefacts from time to time: few black pixels occurring around the mouse pointer while moving or resizing windows - need to look into this a bit more later…
* I am actually working on a Pine GD5434 card. Made 5 of them at JLCPCB with most of the SMD parts already mounted. Had to add a diode, the OSC and one of the logic chips by hand - and of course the GD5434 and the RAM chips. The GD got soldered this morning, the RAMs will follow during the week. Kinda curious if the card will finally work…
- IMG_5026.jpeg (811.17 KiB) Viewed 1647 times
* If it works, I will complete the other 4 cards - and then I might have 2 or 3 for sale. The RAMs I had already at hand and the GD I sourced from the US (approx. EUR 160,- for 5 chips including shipment&taxes…). The 5 PCBs wer costing another EUR 250,- plus another EUR 50,- for the EPROM, socket and VGA jack. In total not really cheap - but cheaper than the hilarious prices of GD5434 ISA cards at eBay…
@PhilC sold me a blank PCB for the Excelgraph - so, this will be the next project. Sourced a w32i Chip from China. Then I can compare the Pine with the Excelgraph. Sadly only one can work inside the Raven at the end of the day…
* Still making up my mind, if I will switch to HDDRIVER (using the new efix101.prg) or stick with the EmuTOS IDE driver. But I think I will find out when I install MagiC
* And: still wondering, if I can mix FAT16 and Atari partitions on one CF when installing MagiC. Do not want to loose the convenience of simply copying files to the CF on the PC…
* Got my Ethernet card working - at least with the UIP tool and copied files from my Mac using FTP? So, even if I loose FAT16 partitions on the CF, at least this can be used for copying files easily
* Changed the PicoPSU I used so far to a beQuiet ATX PSU. Somehow the PicoPSU acted strangely on power-down. The 5V was switched of (so the Raven got powered down) but somehow the RBG lighting of the fans did not switch off. Seems this is driven from 12V which did not got switched off. Didn’t like that…
* Ah yes - soundcard(s)… still need to configure the PicoGUS and the ESS1868F. The ESS card has a Dreamblaster S2 Wavetable board attached… lets see…
- IMG_5024.jpeg (194.34 KiB) Viewed 1647 times
* What games or sound programms do you recommend to install to take advantage of the soundcards?
Cheers
Michael
