LarryL - another Raven060 Adventure
agranlund
Re: LarryL - another Raven060 Adventure
Post by agranlund »
Oh wow, how hard was that to solder? :)
I actually find it quite easy to solder these by hand using a fine tipped iron, rather than with hot air. Even with my shaky hands. Of course you'll want to make sure the chip is good before you start :D
LarryL
Post by LarryL »
agranlund wrote: Thu Jul 02, 2026 7:01 pm Oh wow, how hard was that to solder? :)
Easier than expected :D
Some flux on the Adapter - the side with the round pads
Then I fixed the adapter flush on top of the PLCC footprint and fixed it with some (more) tape
Since I made the PCBs a bit too large it was not that easy to center them exactly - but I managed…
I double checked with a lamp from the opposite side, to see, if the pads are shining through the THT holes
Then a lot of flux inside the THT holes
I then used a standard solder tip, and applied heat a bit longer to ensure that the heat (and the solder) reaches the pads on the adapter
LarryL
Post by LarryL »
PhilC wrote: Thu Jul 02, 2026 7:04 pm I actually find it quite easy to solder these by hand using a fine tipped iron, rather than with hot air. Even with my shaky hands. Of course you'll want to make sure the chip is good before you start :D
Ah, sure - the PLCCs themselves…
Yes, pretty standard tip (not that small) - using lots of flux prevents from shorts
And Nessi can be programmed via the JTAG port :mrgreen:
I have attached a little Raspi Zero W permanently to my Raven (power can be switched on/off, only if needed)
