Different compilers for compiling TOS ?
General Discussion, STOS.
Re: Different compilers for compiling TOS ?
Tried installing MSYS..
UCRT64 ~
# pacman -Syu
:: Synchronizing package databases...
mingw32
mingw32.db failed to download
mingw64.db failed to download
ucrt64.db failed to download
clang32.db failed to download
clang64.db failed to download
error: failed retrieving file 'ucrt64.db' from mirror.msys2.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'clang32.db' from mirror.msys2.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'clang64.db' from mirror.msys2.org : SSL certificate problem: unable to get local issuer certificate
warning: too many errors from mirror.msys2.org, skipping for the remainder of this transaction
error: failed retrieving file 'mingw32.db' from mirror.msys2.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'mingw64.db' from mirror.msys2.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'ucrt64.db' from repo.msys2.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'clang32.db' from repo.msys2.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'clang64.db' from repo.msys2.org : SSL certificate problem: unable to get local issuer certificate
warning: too many errors from repo.msys2.org, skipping for the remainder of this transaction
error: failed retrieving file 'mingw32.db' from repo.msys2.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'mingw64.db' from repo.msys2.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'clang64.db' from mirror.umd.edu : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'mingw32.db' from mirror.umd.edu : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'mingw64.db' from mirror.umd.edu : SSL certificate problem: unable to get local issuer certificate
warning: too many errors from mirror.umd.edu, skipping for the remainder of this transaction
error: failed retrieving file 'ucrt64.db' from mirror.umd.edu : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'clang32.db' from mirror.umd.edu : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file 'clang64.db' from mirror.yandex.ru : SSL certificate problem: unable t
So thats a nope then. I downloaded a older version which should have worked with Windows 7 as well.
Tried installing on Linux...
:sigh:
exxos wrote: Mon Oct 27, 2025 8:11 pm Tried installing on Linux...
:sigh:
The first command failed so the second one will.
Internet seems to say 'run the first command again and it will probably work', which I don't find satisying, but there we go.
Then perhaps add an 'apt update' between the PPA and install commands.
Badwolf wrote: Tue Oct 28, 2025 9:38 am The first command failed so the second one will.
I did run them again, it didn't seem to error on the apt stuff the second time, but still couldn't download the files from vinces site anyway.
exxos wrote: Tue Oct 28, 2025 9:47 am I did run them again, it didn't seem to error on the apt stuff the second time, but still couldn't download the files from vinces site anyway.
Let me see if I can spin you up a VM.
Here you go. There's nothing sensitive in here and anyone should be able to use it. It's just proof of concept, really. No bells nor whistles.
This is probably taking the Mickey out of the forum's file hosting, but feel free to download it and delete the attachment if you wish.
This is a Virtualbox image. It'll expand to about 2GB and could use up to 8GB if you filled up its disc. Install Virtualbox and choose 'Add' from the main panel.
Before you boot, edit its settings and tell it your network card to use for the bridge.
It'll boot to a commandline only Debian install and try to advertise to you its IP address on the login prompt which will let you SSH into it.
It should also respond as a samba mount: (start->run) \\exxos.local\exxos
Username is exxos. Password is exxos.
In the home directory is a git-cloned repository of Thorsten's TOS2/3 work.
I have run make with the parameters for the UK TOS2.06 version. It's worked and made an output file (in glue).
Here's the result of that:
In short: it just works. Use the Samba mount to edit the files and get the images off. Just log in, 'cd' to the repository directory and type
make TOSVERSION=206 COUNTRY=uk
To build it again.
make clean
beforehand to ensure a clean slate.
Exxos.7z
(760.13 MiB) Downloaded 241 times
Badwolf wrote: Tue Oct 28, 2025 11:20 am Install Virtualbox and choose 'Add' from the main panel.
No idea how to do that ? I went looking for it and got to
https://www.virtualbox.org/wiki/Downloads
But then it just said.
At this point I don't even know if your talking about Linux or Windows box?
exxos wrote: Tue Oct 28, 2025 2:48 pm
Why does everything always go wrong for you?! :lol:
https://download.virtualbox.org/virtual ... 95-Win.exe
This downloaded directly upon me clicking it just now.
Badwolf wrote: Tue Oct 28, 2025 3:21 pm Why does everything always go wrong for you?! :lol:
I ask myself that daily for the past 30+ years :)
Thanks.. downloading..
:sigh:
Its not that thing which says "will disable your internet connection while it installs" is it ? I tried to install terriblefires tool chain a few years ago, and the program did that.. I then spent 4 hours trying to get my internet connection to come back on!
exxos wrote: Tue Oct 28, 2025 3:28 pm
:sigh:
I don't think you shoudl be allowed near computers.
Maybe. ISE is distributed as a Virtualbox container, IIRC. You may already have it installed.
I don't use Virtualbox really (I used VMWare Fusion), but it is pretty much the standard for chucking VMs around so it's not some niche bit of kit that no-one's tested.
Locked
Return to “SOFTWARE”
