Shifter Behaviour
Re: Shifter Behaviour
You have the most common SHIFTER version. Extremely unlikely that would be the problem. It could be other issues specific to the machine. Conceivable older GLUE (-38 or -20). Post a high rez picture (or two) to see the whole motherboard. Which TOS version are you using? US or Euro?
http://pasti.fxatari.com
While it won't diagnose the issue you could try "Photochrome" which uses techniques similar to spectrum512 to get high colours
https://www.leonik.net/dml/sec_pcs.py
https://codeberg.org/zerkman/mpp
Principal ASIC Engineer - SystemVerilog, VHDL
STf,STfm,STe,MegaST,MegaSTe,Falcon060
- GadgetUK164
Using UK version of TOS 1.04. I will check what version of GLUE it has!ijor wrote: Mon Sep 22, 2025 1:42 pm You have the most common SHIFTER version. Extremely unlikely that would be the problem. It could be other issues specific to the machine. Conceivable older GLUE (-38 or -20). Post a high rez picture (or two) to see the whole motherboard. Which TOS version are you using? US or Euro?
Everything in general works on the machine - just those higher colour depth "tricks" that try to show box art on PP's HDD adapted games.
I'm curious what it looks like. Could you post a picture?GadgetUK164 wrote: Mon Sep 22, 2025 10:46 am On this STM - stock CPU, I see the same type of issue where the "box art" screen is messed up. What was different about the STM - were later modifications done by the time we got to the STFM which means PP's technique of trying to display box art wont work?!?!
Lynx I / Mega ST 1 / 7800 / Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm / SM124 / SC1435
ATW800/2 / SUBcart / FujiNet / DDD HDD / AT Speed C16 / TF536 / SDrive / PAK68/3 / Lynx Multi Card / LDW Super 2000 / XCA12 / SkunkBoard / CosmosEx / SatanDisk / UltraSatan / USB Floppy Drive Emulator / Eiffel / SIO2PC / Crazy Dots / Mach32 / ET4000 VME / PAM Net
http://260ste.atari.org
Thinking about it a bit, I once had an STM with a suspect glue and various sync related effects would act really strangely.
My 520ST (no F, or M) is on my desk at the moment. If you give me the name of a PP HDD adapted title that you see corruption I will try it.
