Mmm. Then the disc drive?
I wonder if a transfer offset or something is reported in the SCSI protocol & that's overflowing?
WAGing here, sorry. I tried looking at the DMA/ACSI protocol once and decided it wasn't for me. I assume SCSI's worse.
This is why tested the ezdrive yesterday.. Same problem...
Ah. Missed that, sorry.exxos wrote: Wed Sep 24, 2025 3:08 pm 2 different falcons..., 2 different drives.... Jookie knew of these issues before me...
Can you install 12.53 just to make sure something else isn't in the mix..kohli79 wrote: Wed Sep 24, 2025 3:14 pm I did a little testing.
Standard Falcon with 14MB + driver 12.71.
Everything copied with Kobold 3.5.
‘Fast-SCSI’ enabled in HDDRUTIL.APP.
Quickly installed the 12.53 driver. Copied a 50MB file to the SCSI Sun HDD. No errors with Kobold. I'll test the other one tomorrow, then I have to go to work. It seems to hang over TOS...exxos wrote: Wed Sep 24, 2025 3:23 pmCan you install 12.53 just to make sure something else isn't in the mix..kohli79 wrote: Wed Sep 24, 2025 3:14 pm I did a little testing.
Note it needs to be installed as dont think just running driver works..
Clean boot... Use TOS copying..
I tried kobold... Same problem..kohli79 wrote: Wed Sep 24, 2025 3:35 pm No errors with Kobold. I'll test the other one tomorrow, then I have to go to work. It seems to hang over TOS...![]()
Confirmed it worked by ~10MB free listed in desktop config.Badwolf wrote: Wed Sep 24, 2025 12:13 pm Here's a small program that does nothing but steal ST-RAM from your system starting as low as possible in memory.
