ST536NG build
Re: ST536NG build
Good progress. :thumbup:
spen
Re: ST536NG build
Post by spen »
Dried, plugged in. Current consumption was ok. :)
Photo 29-11-2025, 21 53 30.jpg (140.54 KiB) Viewed 109 times
Ok, fired up. It responded and erased just fine. 8-)
Photo 29-11-2025, 21 53 20.jpg (72.97 KiB) Viewed 109 times
@exxos - What's the most appropriate fw to flash on it?
edit - I just put https://www.exxosforum.co.uk/atari/last ... NT30SS.zip on there. I'll solder the header pins and cpu socket tomorrow.
Re: ST536NG build
You need the BETA1SS firmware else you probably kill the osc or PLD.
spen
Re: ST536NG build
Post by spen »
Reflashed with BETA1SS fw. Headers and socket added.
Then I hit the first snag. I discovered I have no free 030s :? Removing them is a perilous task.
I'm not doing that again. :shock: :shock: :chairsmack:
This will take a couple of days to fix.
Re: ST536NG build
:o :o :o Never seen that happen before..
spen
Re: ST536NG build
Post by spen »
exxos wrote: Sun Nov 30, 2025 1:22 pm :o :o :o Never seen that happen before..
I don't want to see that happen again. Far too much haste.
Re: ST536NG build
spen wrote: Sun Nov 30, 2025 2:48 pm I don't want to see that happen again. Far too much haste.
I use a wallpaper scraper to start it off :)
Hopefully you will have better luck getting running than others are having.. I'm fast running out of things to fix :roll:
HigashiJun
Re: ST536NG build
Post by HigashiJun »
Ouch ! :shock:
I have also my tool to remove that kind of CPUs:
spen
Re: ST536NG build
Post by spen »
exxos wrote: Sun Nov 30, 2025 2:56 pm
I'm sure everyone could generate lots of ideas !! :lol: :lol:
spen
Re: ST536NG build
Post by spen »
HigashiJun wrote: Mon Dec 01, 2025 1:23 am Ouch ! :shock:
I like it. :) I'm thinking of two ways forward, but it'll be a few days. No more broken 030s, or anything PGA.
