Why? What's the clamp for, then? It's a bit thin to act as a heat sink, isn't it?rubber_jonnie wrote: Thu Sep 04, 2025 6:27 pm Glad to see it working, and I'd suggest that you reinstall the clamp![]()
STE without Blitter chip?
Reluctant16bitter
Re: STE without Blitter chip?
Atari 1040STE (4 MB RAM) | Sinclair ZX Spectrum +2A | Sony HB-F1XV MSX2+ (512 KB RAM, 7MHz Z80, WozBlaster OPL4, PowerGraph Light V9990) | Philips VG8235 MSX2 (1 MB RAM, 7MHz Z80) | Mitsubishi ML-FX1 MSX
It's there to prevent blitter thievesReluctant16bitter wrote: Thu Sep 04, 2025 7:16 pm Why? What's the clamp for, then? It's a bit thin to act as a heat sink, isn't it?
d:m:l
Home: http://www.leonik.net/dml/sec_atari.py
AGT playlist https://www.youtube.com/playlist?list=P ... GzrdrZJxgM
Quake II playlist: http://www.youtube.com/playlist?list=PL ... 5nMm10m0UM
It's to prevent the socket from bulging outwards and breaking contact with the chip over time.Reluctant16bitter wrote: Thu Sep 04, 2025 7:16 pm Why? What's the clamp for, then? It's a bit thin to act as a heat sink, isn't it?
For this reason.exxos wrote: Thu Sep 04, 2025 7:59 pmIt's to prevent the socket from bulging outwards and breaking contact with the chip over time.Reluctant16bitter wrote: Thu Sep 04, 2025 7:16 pm Why? What's the clamp for, then? It's a bit thin to act as a heat sink, isn't it?
Reluctant16bitter
That sounds useful. I'll open it up again.
