BLITTER RE-CREATION THOUGHTS
Progress on our FPGA cores.
mmx01
Re: BLITTER RE-CREATION THOUGHTS
Post by mmx01 »
More I look at the timings, more I think PLL should be clocked from external crystal and CLK as signal synced to Atari. This would sync bus events but not impede logic operations. Perhaps that's a dead ally but first impression is that processing is consuming too many cycles. Or fiddle with P_CYCLE_CNT: process.
mmx01
Post by mmx01 »
Tried to get blitter on 16Mhz clock from MMU pin 5 but it did get messy, division of clock counts in fpga code did not seem to improve anything. I wish I had designed some pads around clock source configuration but yeah...
Thanks to great input from @Icky and a lot of hacking hours not fully understanding ports, port maps and how to pass different signals in vhdl finally some progress! This code provided other insights how to further tune fpga blitter:
https://github.com/gyurco/MiSTery/commi ... 6f252776f7
Still not good though, lines no longer spread over time but top part is distorted. Playing with 32Mhz vs. 64Mhz clocks is not delivering further benefits.
Stock code - blitting score in mid-res: time 5.965
New code - blitting score in mid-res: time 6.600
Hmm. not going in the right direction but at least new code is working and not freezing the machine like it did for 2 days ;) Next seems to be waitstates, T_SLICE and CYCLE_CNT. T_SLICE I am feeding 8Mhz and overall clock is 32Mhz I will try to rewrite with raising edge & falling edge. CYCLE_CNT for HOG is 80/40.
Thought I would do the final spin of the Phoenix Sparkalaphobia board now that the dev boards are functioning and its down to the firmware tweaks to complete.
This board is designed to fit directly into a PLCC68 socket as a drop in replacement of an original BLITTER chip.
Of course the most limiting factor now is the FPGA chip shortage.
Screenshot 2022-10-15 at 13.46.00.png (980.59 KiB) Viewed 1969 times
Screenshot 2022-10-15 at 13.47.02.png (452.24 KiB) Viewed 1969 times
Screenshot 2022-10-15 at 13.42.12.png (837.72 KiB) Viewed 1969 times
Icky wrote: Sat Oct 15, 2022 1:53 pm This board is designed to fit directly into a PLCC68 socket as a drop in replacement of an original BLITTER chip.
Looking good. What chips are you using for the level shifting there, BTW?
Badwolf wrote: Sat Oct 15, 2022 2:03 pm
GTL2010PW - https://www.ti.com/lit/ds/symlink/sn74gtl2010.pdf
@exxos had done various testing of translators and we have found these to be best suited to our needs. Its also the same ones we use on the H5 boards to provide the 3V3 bus. I cant seem to find the thread on @exxos' experiments.
Icky wrote: Sat Oct 15, 2022 2:17 pm GTL2010PW - https://www.ti.com/lit/ds/symlink/sn74gtl2010.pdf
Cheers, will have a look at those. My normal ones are only 8 bits wide and are occasionally unobtanium.
Icky wrote: Sat Oct 15, 2022 2:17 pm @exxos had done various testing of translators and we have found these to be best suited to our needs. Its also the same ones we use on the H5 boards to provide the 3V3 bus. I cant seem to find the thread on @exxos' experiments.
Its all at the start of this thread. Experiments are scattered over several pages.
viewtopic.php?p=9808#p9808
The GTL chips were the only ones I could get to work right. Even Texas versions of the same chip were screwy IIRC.
Tbs123456
Post by Tbs123456 »
Is it a 100% blitter replacement?
Where did the name sparkalaphobia(pronounced spark-ala-phobia?) Come from?
Tbs123456 wrote: Sat Oct 15, 2022 4:31 pm Is it a 100% blitter replacement?
Yes. Its a project to offer a alternative to the impossible to find Blitter chips.
Tbs123456 wrote: Sat Oct 15, 2022 4:31 pm Where did the name sparkalaphobia(pronounced spark-ala-phobia?) Come from?
Sparkalaphobia - The fear of Glitter.. Glitter as autocorrect keeps changing Blitter to Glitter :lol: :roll:
Cyprian
Post by Cyprian »
how to buy that glitter
my ST is waiting for it
http://260ste.atari.org
Return to “FPGA DEVELOPMENT”
