mrbombermillzy wrote: Tue Aug 19, 2025 8:08 pm
Once you do what you need to do to test the drive loading with the SD2IEC, I would be extremely greatful if I could get a regular IEC connector on there, so I can use my trusty old 1541 and floppies and other options, should the SD2IEC fail, or be incompatible with something.
I don't think I'll be getting it going before I go on my hols, and I don't have an IEC socket, but will order one to arrive as I'm getting home. That way I can test my SD2IEC on it which has a separate power connector and will run just fine off a battery pack.
I would like to see it working though, the SD2IEC seems to be giving a flash code, so I'll go and look them up.
PhilC wrote: Tue Aug 19, 2025 8:12 pm
I'll have to dig out my DTV and try it again. I wonder if it does indeed have a working keyboard port after all.
Definitely worth a try.
rubber_jonnie wrote: Tue Aug 19, 2025 10:33 pm
All in your own time.
It should give @PhilC a chance to dig out his DTV and come up to speed.
So I've done a little testing with the latest SD2IEC firmware and there is still an issue. I also tried other SD cards. Still a no go, The LED's shouldn't be flashing when the SD2IEC is initialised, and they are.
One thing I noticed is that one of the TAC switches is damaged:
And I did wonder if it was jammed, but seemingly not.
I need to figure out what the jumpers are too as they aren't clear, but seem to make no difference. IEC socket is on the way.
rubber_jonnie wrote: Wed Aug 20, 2025 10:40 am
Oh dear.
Would you believe me if I told you that damage was actually the 'repair shop' I took it to?
I think this may be looking like the way forward, if - as it seems - the SD2IEC isnt co-operating.
mrbombermillzy wrote: Wed Aug 20, 2025 10:47 am
Oh dear.
Indeed...
I would. What did it go to a repair shop for?
Yes and I can at least test with my known good SD2IEC then. I have also got a 6 pin DIN plug on the way which I'll attach to your SD2IEC for testing.
rubber_jonnie wrote: Wed Aug 20, 2025 10:54 am
To re-attach a couple of wires that had pinged off of the power LED module IIRC. So not anything major really.
Interesting story...
The guy didnt charge me, but was quite 'upset'/angry (with the board!) and told me not to come back.
I dont think he enjoyed fixing it.
Nice one. Thanks.
Although I have a feeling I may have to dig out the Pi1541.
Nice one. Thanks.
Do you recall where you got it from? There seem to be 1001 different types that all do the same thing but that are designed slightly differently.
Do you recall what those wires were? Was it attached to the DTV at that point?
Seems like he was not familiar with SMD soldering!!!
