Just found it.
.include hardware
.include defs
.include nvram
.include macros
.include "scrn16.gbl"
.extern pasmsg,falmsg,erflg0,dspreg
.extern DSPRAMTEST,DSPSSITEST,dsptest
* DSP.S : Sparrow DSP routines
* V0.0 : 26MAR92 : RWS : Works
* V0.1 : 20MAY92 : RWS : Hacked up for RTC status bits.
* V0.2 : 11JUL92 : RWS : Changed for Rev. 3 boards
DSPREV = 2
.macro TRISTATEMATRIX
move.w #$0000,DATAMXSRC
move.w #$0000,DATAMXREC
.endm
.macro SSISTATEMATRIX
; move.w #$0010,DATAMXSRC
; move.w #$0010,DATAMXREC
move.w #$0008,DACRECCTRL ; global sound reset
nop
move.w #$0000,DACRECCTRL
; move.w #$0000,DATAMXSRC
; move.w #$0000,DATAMXREC
.endm
.text
; DSP Host interface constants
.if DSPREV = 0
DSPICR = $ffffa201 ; Interrupt Control Register
DSPCVR = $ffffa203 ; Command Vector Register
DSPISR = $ffffa205 ; Interrupt Status Register
DSPIVR = $ffffa207 ; Interrupt Vector Register
DSPRXH = $ffffa20b ; Receive byte High
DSPRXM = $ffffa20d ; Receive byte Mid
DSPRXL = $ffffa20f ; Receive byte Low
DSPTXH = $ffffa20b ; Transmit byte High
DSPTXM = $ffffa20d ; Transmit byte Mid
DSPTXL = $ffffa20f ; Transmit byte Low
.endif
.if DSPREV = 1
DSPICR = $ffffa200
DSPCVR = $ffffa202
DSPISR = $ffffa204
DSPIVR = $ffffa206
DSPRXH = $ffffa20a
DSPRXM = $ffffa20c
DSPRXL = $ffffa20e
DSPTXH = $ffffa20a
DSPTXM = $ffffa20c
DSPTXL = $ffffa20e
.endif
.if DSPREV = 2
DSPICR = $ffffa200 ; Interrupt Control Register
DSPCVR = $ffffa201 ; Command Vector Register
DSPISR = $ffffa202 ; Interrupt Status Register
DSPIVR = $ffffa203 ; Interrupt Vector Register
DSPRXH = $ffffa205 ; Receive byte High
DSPRXM = $ffffa206 ; Receive byte Mid
DSPRXL = $ffffa207 ; Receive byte Low
DSPTXH = $ffffa205 ; Transmit byte High
DSPTXM = $ffffa206 ; Transmit byte Mid
DSPTXL = $ffffa207 ; Transmit byte Low
.endif
; HOSTVECT = $3fc ; interrupt vector number 255
; define test result codes for SSI loopback
LB_TESTING EQU $000050 ; testing begun (not passed)
LB_TIMEOUT EQU $000051 ; no data received (failure)
LB_NOT_EQUAL EQU $000052 ; data recv != data xmit (failure)
LB_SUCCESS EQU $000053 ; test successful (pass)
;* Test IDs for RAM1 Test
MT_TESTING EQU $111111 ; test started, but not yet passed
MT_SUCCESS EQU $123456 ; Test passed
MT_ALL_ONES EQU $200000 ; Leave the LS bits = 0 for OR ing with the address.
MT_ALL_ZEROS EQU $300000
MT_ALL_AA EQU $400000
MT_ALL_55 EQU $500000
MT_RANDOM EQU $600000
MT_WALK_ONES EQU $700000
* DSP TESTS FROM MENU
;dsptest:
; lea.l dspm,a5
; bsr dsptst
; bsr DSPRAMTEST
; move.l a5,d2
; bsr DSPSSITEST ; test DSP SSI CONNECTOR
; cmp.l #pasmsg,a5
; bne .Fail
; cmp.l #pasmsg,d2
; bne .Fail
;.Pass:
; RTCSETPASS #t_DSP
; rts
;.Fail:
; RTCSETFAIL #t_DSP
; lea.l falmsg,a5
; move.w #red,palette
; rts
.if 0
* DSPLoad - load a program into DSP
* entry: a0 = address of DSP code in 32 bit LW's (upper byte = 0)
* (terminated by $ffffffff)
* format is {DATA P0 implied} $00XXXXXX ... $ffffffff (endmark)
* exit: DSP ready to go..
DSPLoad:
movem.l d0-d1/a0,-(sp)
; - RESET DSP
; bset.b #3,mfp+ddr ; set MFP i/o bit 3 to output
; bclr.b #3,mfp+gpip ; set bit 3 i/o low
bsr DSPRead ;get any junk out of host port
move.b #7,psgsel
move.b #$c0,psgwr
move.b #14,psgsel
move.b #00,psgwr
move.b #14,psgsel
move.b #$10,psgwr
move.w #$ffff,d1 ; wait a bit (was : 1 tick of 200Hz) dunno if this is long enuf.
.dly:
nop ; bubbles in the pipe!
nop
dbra d1,.dly
move.b #14,psgsel
move.b #00,psgwr
; bset.b #3,mfp+gpip ; set bit 3 high
; - DUMP IN DATA
.dump0:
move.l (a0)+,d0 ; get first word
bmi .exit
bsr .DoLoad
clr.w d1
move.b d0,d1
sub.w #1,d1
move.l #0,d0
.lp: ; fill up NOP space (to $40 usually)
bsr .DoLoad
nop
dbra d1,.lp
.dump1:
move.l (a0)+,d0 ; get next DSP data word
bmi .exit ; non zero MSbit = exit
bsr .DoLoad ; no, send it to DSP
bra .dump1
.exit:
movem.l (sp)+,d0-d1/a0
rts
* loads a longword in d0 into DSP (lower 3 bytes ONLY)
.DoLoad:
move.l d0,DSPTXH-1
; swap d0 ; I hope handshaking is in hardware
; move.b d0,DSPTXH
; rol.l #8,d0
; move.b d0,DSPTXM
; rol.l #8,d0
; move.b d0,DSPTXL
rts
.endif
OldDSPLoad:
; - RESET DSP
;; bset.b #1,DDR2 ; set MFP i/o bit 3 to output
;; bclr.b #1,GPIP2 ; set bit 3 i/o low
move.b #7,psgsel
move.b #$c0,psgwr
move.b #14,psgsel
move.b #00,psgwr
move.b #14,psgsel
move.b #$10,psgwr
move.l #$ffff,d1 ; wait a bit (was : 1 tick of 200Hz) dunno if this is long enuf.
.dly:
nop
dbra d1,.dly
move.b #14,psgsel
move.b #00,psgwr
; bset.b #1,GPIP2 ; set bit 3 high
; - DUMP IN DATA
.dump1:
bra .dump1
.exit:
rts
.DoLoad:
move.l d0,DSPTXH-1
; move.b d0,DSPTXH
; rol.l #8,d0
; move.b d0,DSPTXM
; rol.l #8,d0
; move.b d0,DSPTXL
rts
* loads d0.l from DSP (lower 3 bytes ONLY)
DSPRead: ; I hope handshaking is in hardware
move.l DSPTXH-1,d0
andi.l #$00ffffff,d0
; clr.l d0
; move.b DSPTXH,d0
; rol.l #8,d0
; move.b DSPTXM,d0
; rol.l #8,d0
; move.b DSPTXL,d0
rts
* DSPRun - starts the DSP executing
* if less than 512 words loaded into DSP ram
DSPRun:
;- SET HF0 in Host ICR
bset.b #3,DSPICR ;set flag 0 to 1 to signal end of transfer
rts
* SSI LOOPBACK TEST (comments from SSI.asm)
* Test of DSP56k's SSI port by connecting it back to itself.
* To perform this test, connect:
* STD to SRD
* SCK to SC0 (SCK output, SC0 input, asynchronous mode clocks)
* SC1 to SC2 (mode to be defined)
;* The SSI loopback test will begin by writing LB_TESTING to the 56k's
;* Host Interface Data Register, HTX. It will then try to send and
;* receive LB_NUM_WORDS via the SSI in loopback mode. If the received
;* data does not match the transmitted data, it will return LB_NOT_EQUAL
;* to the HTX register. If the test times-out while waiting for data to
;* be received, then it will send a LB_TIMEOUT to the HTX register. If
;* it sends and receives all of the words correctly, it will send a
;* LB_SUCCESS to the HTX register. If the test fails completely, then
;* LB_TESTING will be left in the HTX register, so the host (your 68xxx
;* CPU) should give up after 2-3 seconds and consider the test hung (a
;* failure). See the section, Initialize SSI Port (baud rate
;* determination by setting CRA_BITS), for timing information.
* You can test this program by disconnecting wires in the loopback.
* If you disconnect STD-SRD you should get a LB_NOT_EQUAL
* If you disconnect SCK-SC0 you should get a LB_TIMEOUT
* If you disconnect SC1-SC2 you should get a LB_TIMEOUT
DSPSSITEST:
; - TURN OFF CACHE
;;RWS.TPEX move.l d2,-(sp)
;; clr.b d2 ; OnceFlag
;;RWS.TPE bclr.b #5,SPControl ; turn off bus errors.
movecacrd0
move.l d0,d3 ; save old cache status
move.l #$00000000,d0 ; DISABLE I & D CACHES on 030
moved0cacr
SSISTATEMATRIX
lea.l DSPL0msg,a5
bsr dspmsg
.ReTest:
;RWS.TPED move.b #'.',d1
; bsr ascii_out
lea.l DSPSSIHEX,a0
bsr OldDSPLoad
bsr DSPRun
move.l #$fffff,d1
.isstart:
btst.b #0,DSPISR ; wait for data ready bit
bne .getdata
subq.l #1,d1
bne .isstart
bra .notstart ; timed out
.getdata:
bsr DSPRead
cmpi.l #LB_TESTING,d0 ;if not testing, error not started
beq .started
bra .notstart
.started:
move.l #$fffff,d1
.isdone:
bne .getdata2
subq.l #1,d1
bne .isdone
bra .notdone ; timed out while running
.getdata2:
bsr DSPRead ; the next thing out will be a message
cmpi.l #LB_SUCCESS,d0
beq .success
cmpi.l #LB_TIMEOUT,d0
bne .ntime
;;RWS.TPED cmpi.b #3,d2 ;OnceFlag
;; bgt .Lost
;; addq.b #1,d2 ; ok, one more try
;; bra.s .ReTest
.Lost:
lea.l DSPL2err,a5 ; timeout error
bra .fail
.ntime:
cmpi.l #LB_NOT_EQUAL,d0 ;not same data error
bne .notdone
lea.l DSPL3err,a5
bra .fail
.notstart:
lea.l DSPL0err,a5
bra .fail
.notdone:
lea.l DSPL1err,a5
bsr dspmsg
.fail: ; - DO FAIL STUFF
or.b #1,erflg0
bsr dspmsg ;show off message
movea.l #falmsg,a5
* bsr dspmsg
move.w #red,palette
bra .exit
.success:
movea.l #pasmsg,a5
bsr dspmsg
bsr crlf
* move.w #green,palette
; - DO PASS STUFF!
.exit:
move.l d3,d0 ; RESTORE CACHES
moved0cacr
;;RWS.TPE bset.b #5,SPControl ; turn on bus errors.
;;RWS.TPED move.l (sp)+,d2
rts
* DSP RAM TEST (comments from RAM1.asm)
;* When the program begins testing, it writes a MT_TESTING to the Host
;* Interface data register, HTX. If the test succeeds, MT_SUCCESS will
;* be put in the HTX register. If it fails, the test ID will be ORed
;* with the 16 bit address of the memory that failed and put in the HTX
;* register. For example, if a $604E5F is returned, the $6 means the
;* random value memory test (see Test IDs below) failed at address $4E5F.
;* The test indicates memory failure if the host (68xxx CPU) does not
;* see a MT_SUCCESS flag in a few seconds (or the program has died from
;* a 56k failure. The complete RAM test took 0.78 seconds on a 27 Mhz
;* 56001. Most of the time is spent running the WalkingOnes test.
DSPRAMTEST:
lea.l DSPR0msg,a5
bsr dspmsg
.DRAMT:
; - TURN OFF CACHE
movecacrd0
moved0cacr
TRISTATEMATRIX
; lea.l DSPRAM1HEX,a0
; bsr OldDSPLoad
; bsr DSPRun
lea.l DSPRAM1HEX,a0
bsr OldDSPLoad
bsr DSPRun
move.l #$fffff,d1
.isstart:
bne .getdata
subq.l #1,d1
bne .isstart
.getdata:
bsr DSPRead
cmpi.l #MT_TESTING,d0
beq .started
bra .notstart ; some strange error here.. not running code though
.started:
move.l #$fffff,d1
.isdone:
bne .getdata2
subq.l #1,d1
bne .isdone
.getdata2:
bsr DSPRead
cmpi.l #MT_SUCCESS,d0
beq .success
cmpi.l #MT_TESTING,d0 ;RWS.T attempt to fix the dsp power on prob.
beq .started ;RWS.T
lea.l DSPR2err,a5
bsr dspmsg
move.l d0,a0
bsr dspadd ; show failure code
bsr crlf
bra .fail
.notstart:
.notdone: ; timedout
lea.l DSPR1err,a5
bsr dspmsg
; - DO FAIL STUFF!
.fail:
;;;RWS.TPE 1.18d sub.w #1,tries
;;; bne DSPRAMTEST
;TEMP FOR TAIWAN RUN #1 (for some reason sound only works occasionally)
* movea.l #falmsg,a5
move.w #red,palette
or.b #1,erflg0 ; set RAM fail bit
bra .exit
.success:
move.l #pasmsg,a5
bsr dspmsg
bsr crlf
; - DO PASS STUFF!
.exit:
moved0cacr
rts
* SAMPLE DSPCODE FROM DSPBIND.ASM
* GO LOOK THERE IF YOU WANT IT.
.data
* DSP HEX CODE BELOW!
* SSI test 27MAR92 : RWS
* sent from SUVL - source in \dsp\dsptests\ssi.asm
* CHANGED SLIGHTLY 27MAR92 : RWS
SSIDELY = $006100 ;bit time delay !!NOTE!! THESE VALUES FAIL IF A LONG CABLE
;SSIDELY = $006400 ;bit time delay !!NOTE!! THESE VALUES FAIL IF A LONG CABLE
SSIWAIT = $000000 ;0ws ram IS USED FOR LOOPBACK. KEEP IT SHORT!!
SSIMAXW = $001500 ; max wait for chars
;SSIMAXW = $015000 ; max wait for chars
SSITSTG = $000050
SSITIMO = $000051
SSINEQU = $000052
SSISUCC = $000053
; SSITSTG = $222222
; SSITIMO = $122334
; SSINEQL = $112233
; SSISUCC = $654321
.even
.if 0
DSPSSIHEX:
;_START SSI1 0000 0000 0000 DSP56000 4.1.1
;_DATA P 0000
dc.l $0C0040
; - nop out to program at $40
; dc.l $000000,$000000,$000000,$000000,$000000,$000000,$000000,$000000,$000000,$000000
; dc.l $000000,$000000,$000000 ; ,$000000 ;<-???
;_DATA P 0040
dc.l $0003F8,$08F4BE,SSIWAIT,$08F4AB,SSITSTG,$0BF080,$00006F,$0BF080
dc.l $00004D,$08F4AB,SSISUCC,$0AF080,$00006D,$0004FA,$60F400,$000100
dc.l $05FFA0,$200013,$2C0100,$218700,$54F400,$00EA60,$4CD800,$08C42F
dc.l $57F400,$001500,$0AAEA7,$000062,$20007C,$0E705A,$08F4AB,SSITIMO
dc.l $0AF080,$00006D,$084F2F,$20004D,$0AF0A2,$000069,$200074,$0E7056
dc.l $00000C,$08F4AB,SSINEQL,$0AF080,$00006D,$000086,$0C006D,$08F4BF
dc.l $002C00,$08F4AC,SSIDELY,$08F4A3,$000000,$08F4A1,$0001FF,$0BAE24
dc.l $08F4AF,$000000,$08F4AD,$003130,$00000C
;_SYMBOL P
;SineTest I 00004D
;BadData I 000069
;DeadLoop I 00006D
;SetupSSI I 00006F
;_END 0000
dc.l $ffffffff
.endif
.even
DSPSSIHEX:
;_DATA P 0000
dc.l $0C0040
;_DATA P 0040
dc.l $0003F8,$08F4BE,SSIWAIT,$08F4AB,$000050,$0BF080,$00006F,$0BF080
dc.l $00004D,$08F4AB,$000053,$0AF080,$00006D,$0004FA,$60F400,$000100
dc.l $57F400,$015000 ; was 001500
dc.l $0AAEA7,$000062,$20007C,$0E705A,$08F4AB,$000051
dc.l $00000C,$08F4AB,$000052,$0AF080,$00006D,$000086,$0C006D,$08F4BF
;_SYMBOL P
;SineTest I 00004D
;BadData I 000069
;DeadLoop I 00006D
;SetupSSI I 00006F
;_END 0000
dc.l $ffffffff
* RAM1 test 26MAR92 : RWS
* sent from SUVL - source in \dsp\dsptests\ram1.asm
DSPRAM1HEX:
;_START RAM1 0000 0000 0000 DSP56000 4.1.1
;_DATA P 0000
dc.l $0C0040
dc.l $000000,$000000,$000000 ;- $000000 ???
;_DATA P 0040
dc.l $0003F8,$08F4BE,$000000,$08F4AB,$111111,$0BF080,$00004F,$0BF080
dc.l $00009A,$0BF080,$000078,$08F4AB,$123456,$0AF080,$0000BF,$272000
dc.l $44F400,$FFFFFF,$0BF080,$000063,$273000,$240000,$0BF080,$000063
dc.l $274000,$44F400,$AAAAAA,$0BF080,$000063,$275000,$44F400,$555555
dc.l $0BF080,$000063,$00000C,$60F400,$000200,$45F400,$007E00,$06C520
dc.l $075884,$60F400,$000200,$45F400,$007E00,$56F400,$C3C3C3,$06C500
dc.l $000076,$07E08F,$20004D,$07588E,$0AF0A2,$0000C1,$000000,$00000C
dc.l $277000,$20001B,$240000,$0BF080,$000093,$60F400,$000200,$45F400
dc.l $007E00,$200013,$06C500,$000091,$2C0100,$061880,$00008F,$07508C
dc.l $07588F,$07E084,$218E00,$200045,$0AF0A2,$0000C2,$200032,$000000
dc.l $200013,$07588E,$00000C,$60F400,$000200,$45F400,$007E00,$06C520
dc.l $075884,$00000C,$276000,$60F400,$000200,$45F400,$007E00,$57F400
dc.l $987654,$06C500,$0000A9,$20003A,$0AF0A5,$0000A9,$46F400,$1D872B
dc.l $20005B,$07588D,$60F400,$000200,$45F400,$007E00,$57F400,$987654
dc.l $06C500,$0000BD,$20003A,$0AF0A5,$0000B8,$46F400,$1D872B,$20005B
dc.l $21AE00,$07D884,$200045,$0AF0A2,$0000C1,$000000,$00000C,$000086
dc.l $0C00BF,$07F88E,$220F00,$20007A,$08CD2B,$0C00BF
;_SYMBOL P
;SingleTests I 00004F
;AllSame I 000063
;WalkingOnes I 000078
;PaintMem I 000093
;RandomTest I 00009A
;FillRandLoop I 0000AA
;CheckRandLoop I 0000BE
;DeadLoop I 0000BF
;BadTest I 0000C1
;BadWord I 0000C2
;_END 0000
dc.l $ffffffff
** ERROR MESSAGES **
dspm: dc.b 'Testing DSP',eot
DSPL0msg: dc.b 'Testing DSP SSI Loopback... ',eot
DSPL0err: dc.b 'DSP0 - DSP Not Executing Program',cr,lf,eot
DSPL1err: dc.b 'DSP1 - SSI Test Timeout',cr,lf,eot
DSPL2err: dc.b 'DSP2 - SSI Loopback Timeout',cr,lf,eot
DSPL3err: dc.b 'DSP3 - SSI Bad Data',cr,lf,eot
DSPR0msg: dc.b 'Testing DSP SRAM... ',eot
DSPR1err: dc.b 'DSP4 - SRAM Test Timeout',cr,lf,eot
DSPR2err: dc.b 'DSP5 - SRAM Fail: ',eot
