I think, then, reading that, you might consider a few Raven060 branded accessories.
I know you're thinking about onboard NIC, but, why not design an 8 or 16 bit Raven0560 ISA NIC?
Are the relevant signals on the ISA bus, to add the DMA/Floppy controller? I really miss seeing the floppy on the machine.
Not that it's terribly useful, but. Well. All Atari's up to now have had one
Same with, maybe, the TT video shifter. Or, better, the Falcon Videl or Super Videl
And, the same with the cartridge port ISA card. I know you mentioned ROM3 and ROM4. Nice to have.
I'll probably add them in as a patch lead, and put in the ISA cartridge port from the microATX ST
Maybe even a PicoGUS branded Raven060
Absolutely makes zero difference to the usage of it. But. How cool would that be...
And, given Ian Scott is now working on the PicoIDE, I'd love to add that, as the actual HDD/CDRom device(s).
How cool would that be!!
Actually. Would you need a DMA controller, to add the Falcon's DSP chip?
I wonder how much Falcon software you could get working, just having the DSP on the bus...
Anyhow!
I've two boards just about ready to be programmed.
I flip flopped on adding some of the parts to the board as dual wipe sockets, and then, the TCXOs, too.
(Decided on sockets now, and if I run into problems, I can remove the sockets and solder directly)
On programming, does the jtag port have a 5v diode? can I flash the ATF1508 while the machine is powered off?
Now, I have to figure out how to actually flash it (cheaply!) I've got OpenOCD on the PC, and an ST Link V2, and, let's see what happens...
If there's no rework document yet...
Can we start a thread?
I've swapped C310 for 0.1uF,
I need to run two patch wires for ROM3 and ROM4,
I need to run patch wires for 32MB ram access,
what else...
- 20251119_0909291.jpg (541.21 KiB) Viewed 1308 times
