raspberrypioneer wrote: 05 Nov 2026 10:52
I had come across RGB2HDMI a while back in passing, it's an impressive project and I see it does allow for audio now. I'd be interested to hear how the video quality compares for you with the older 80's retros in general. I have RGB output for the Electron and Oric-1 in my collection (perhaps count the TI99-4A which is component RGB). They output great quality video, I guess HDMI will improve that but not sure my eyes would spot much difference these days. :?
TBH for most of my machines I use either Retrotink or OSSC to convert video to HDMI and for my eyes that is good enough. All have superb output and look great viewed that way.
There are some exceptions though, my BBC B, Acorn Electrons and my TI 99/4a.
The BBC hooks up direct to a TFT via SCART and the picture is amazing, no need for HDMI there. Same for the Electrons using the same cable. The TI is hooked up directly to another TFT via component and the picture quality is off the charts good.
One other machine, my Atari 800 has SVideo out and though I do push that through my Retrotink, the quality using it direct is fantastic, very clear.
For me the RGB2HDMI is kind of a bench or unusual machine solution.
For the Enterprises the connectors are odd, and whilst usable, having made a VGA cable I found the image quality was off and that's the sweet spot for me with the RGB2HDMI. The video quality from them is fantastic. I also have an Acorn Atom specific RGB2HDMI board for my Atom Replica and the video quality from that it fabulous too.
However I do sometimes use my workbench as a spot to run old machines, kind of a guest spot and having RGB2HDMI there is helpful.
I get that - bit of a difference between an actual need and curiosity. I'd be interested if you go ahead with it.
I've just ordered the extender board so it's easier to break out the connection cables and I have a sound extender board on the way too.
I will likely mod my Intellivision, but I have a couple of other projects I need to get out of the way first. It should be a very simple wiring job though.
