USB keyboard adapter
Re: USB keyboard adapter
peters wrote: 26 Jun 2025 11:30 Any PcbWay experts around ?
https://www.pcbway.com/project/sharepro ... fb5d5.html
I selected PCB+assembly and click Add to cart.
It offers a lot of PCB options which I've not changed apart from adding a quantity of 1.
I click Calculate and it shows the price. I think this is for one assembled and 4 or 5 blank pcbs.
Is that it ? Have I missed anything ?
Not sure about board assembly, but for blank PCBs it's a minimum of 5.
TheNameOfTheGame
Post by TheNameOfTheGame »
Decided to go with HIDman-mini as a like the compact design.
5 PCBs ordered from pcbway. I'll do the assembly here and post results.
peters
Post by peters »
I was planning to 3D print the end plates and I was hoping to find a step file for the case (one is mentioned).
I will hit the order button and see what happens.
Thanks.
peters
Post by peters »
My Hidman arrived.
Plugged it in... Nothing. No led, no keyboard, no mouse.
This is my sort of luck with electronics.
TheNameOfTheGame
Ah that sucks.
I have the HIDman-mini PCBs here and parts are on the way. Gonna build up 5 pieces total.
DoG
Post by DoG »
peters wrote: 23 Jul 2025 12:31 My Hidman arrived.
Stupid question, I know but I guess you have programmed the firmware on it? Can I see a pic of the pcb?
peters
Post by peters »
I've just been looking at that. The docs don't mention it apart from upgrading.
Step 1 should be install firmware...
I assumed there would be at least an led to show it was powered from the PS2. Maybe not.
I've spent a couple of hours trying to get the various tools installed in Ubuntu but now I need a usb A to usb A cable .
peters
Post by peters »
The usb A-A cable arrived and I it didn't take long to successfully flash the firmware.
Plugged into the Ubuntu box and it works.
Plugged it into the ps/2 KVM and it works on the Ubuntu box and on the Milan.
At last, no more keyboard and mouse restrictions on the Milan.
Happy.
TheNameOfTheGame
Good to hear! Glad it has worked for you.
peters
Post by peters »
The only thing not working is the wheel mouse and it looks like a firmware issue, it doesn't work on Lubuntu either. I've reported it on GitHub.
I've printed a nice box for it all ready.
Users browsing this forum: CCBot, Qwantbot and 21 guests
