Another case of slow IDE access, MuFastRom slowdown?
68030 + SDRAM + IDE
aera
Re: Another case of slow IDE access, MuFastRom slowdown?
Post by aera »
Hi all,
I've come to provide the resolution.
In the meantime, I changed about everything that might affect it:
New MeanWell PSU, current ROM matching the OS, capacitors, you name it.
It was the damn CF card. I changed it for another and immediately got 3.5MB/s. Don't ask me why I decided to do that last.
Doesn't hurt having done the other upgrades, though :D :D
Thank you Stephen for all your work!
edit: and let it be known that yes, certain CF cards are slower with MuFastRom enabled and changing those might solve all your issues!
matt020
Post by matt020 »
What brand of CF card did you have previously,
and what brand did you switch to, to make it work?
aera
Post by aera »
I had previously used the famous blue-and-white CF with 8GB capacity. I switched it for an older PLATINUM branded one, which I think is a German brand and might not be as ubiquitous elsewhere. It runs perfectly.
This one's only 2GB, so I'm definitely swapping it for another one. I just ordered an 8GB PLATINUM from eBay, and a 16GB SanDisk Extreme. Will find out how well these fare.
aera wrote: Thu Jul 10, 2025 9:55 am I had previously used the famous blue-and-white CF with 8GB capacity. I switched it for an older PLATINUM branded one, which I think is a German brand and might not be as ubiquitous elsewhere. It runs perfectly.
When modding my A500 I found that CF cards were quite unreliable, IIRC a lot identify as removable media rather than fixed disk which can cause issues. I bought a bunch of different sizes (256Mb up to 4GB) and makes, some worked, some didn't and overall the experience was poor.
I swapped to IDE2SD card adapters and all my issues went away.
matt020
Post by matt020 »
rubber_jonnie wrote: Thu Jul 10, 2025 12:06 pm When modding my A500 I found that CF cards were quite unreliable, IIRC a lot identify as removable media rather than fixed disk which can cause issues. I bought a bunch of different sizes (256Mb up to 4GB) and makes, some worked, some didn't and overall the experience was poor.
On the contrary, I have been using CF cards in my Amiga's since 2010 when I got back into the hobby. Never had 1 fail. Not a single one.
matt020 wrote: Fri Jul 11, 2025 1:24 am
Out of curiosity are you using a specific brand/size and do you have a particular flavour of IDE to CF adapter you use? I had nothing but trouble with CF cards in my A500, multiple makes and several different adapters.
I was using a 10cm cable, though I did also try a 5cm, but it made no difference.
matt020
Post by matt020 »
rubber_jonnie wrote: Fri Jul 11, 2025 8:36 am
Mostly Sandisk.
I refuse to buy cheap ones.
And the results are, not a single one has failed.
aera
Post by aera »
I have now also settled on the 16GB SanDisk Extreme. It's the older 60MB/s kind with a black label. I get 3,449,000 bytes/sec on this card according to SysInfo, and boot times and opening drawers are very snappy now.
Note that my TF536 is from AmigaStore which still sells the Rev. 2, I think there is a newer one?
Anyway, very happy with this setup now. :)
Return to “TF536”
