C103414 REV 1.1 - STFM 4 x SMT DRAM
If anyone has a better image please add it!
Re: C103414 - STFM 4 x SMT DRAM
What is that empty section to the right of the empty bank, with the large cap to the top right?
This is the one I've got. Those damn J-leaded chips!
No idea... Looks like a bunch of pointless jumper tracks which basically jump over section of other track doesn't go to anythingrubber_jonnie wrote: Mon Apr 16, 2018 10:53 pm What is that empty section to the right of the empty bank, with the large cap to the top right?
I don't know what those pads are for either, but I can tell you that the left side is connected directly to the data bus. That's where I installed my SIMM socket.
Looks like the designer assumed data bus would have resistors like the address bus. Same spacing, right?
I like the idea that it's a Friday afternoon workaround because they got higher capacity RAM chips
Interesting to see that SIMM socket wires up to it though.
it would seen originally they were pads the resistors later were bridged over the tracks on the PCB, and the original holes just not removed..rubber_jonnie wrote: Thu Apr 19, 2018 5:43 pm I like the idea that it's a Friday afternoon workaround because they got higher capacity RAM chips![]()
I would assume this board came out after the 32 chip RAM version.. And they did not have the resistors on that board.. So I don't really know why they would decide suddenly add resistors, then apparently decide they were not needed and bridge them over with tracks on the PCB...
Here's my version, which is sharp enough to read all chip writings etc.
