Epson HX-20 - Collective brain help required :)
Re: Epson HX-20 - Collective brain help required :)
Well this just arrived, I'm hoping it isn't dead and I can use it as a reference for my other dead one!!! Or I can at least make one good one out of the two machines!!!
I have to say delivery was super quick on this.
HigashiJun
Post by HigashiJun »
Fingers crossed !
HigashiJun wrote: Tue Apr 28, 2026 12:21 pm Fingers crossed !
First thing I think is to pull the battery and see what's what.
OK, so old battery out:
And whilst it looks OK, under the red heat shrink there are strong indications that the battery cans are corroded. Also, rebuilt battery is showing signs of life at about 3.5v and this one shows zero...
No damage to the mainboard though which is good.
I have been charging my pack via the original HX-20 and it charges at about 50mA, but only at about 11mA on the new machine. So I will leave it all afternoon and see what happens.
It is possible I have a dead cell in my rebuilt pack, I built it a long time ago, but we'll wait and see.
However there was just enough power for me to see that the new machine does boot!! It beeps and shows me the CTRL and @ to initialise prompt, so I am hopeful that with a good battery it will run.
However the 'good battery' statement is important because the power supply doesn't power the HX-20, it just chatges the battery, so if I have a bad battery pack I'll need to build a fresh one. Wondering if I can use some spare 18650's..
What batteries are in them? Look like four cells.
PhilC wrote: Tue Apr 28, 2026 2:44 pm What batteries are in them? Look like four cells.
There are indeed 4 cells. My replacement pack used ESP1700SCS 1700mAH Ni-Cad cells:
Will see about getting some more, they are 1.2v cells.
I found a like-for-like replacement on-line for mine. I’ll see if I can find where I got it.
Note that the charging system is very crude, just using a resistor and crossing fingers
stephen_usher wrote: Tue Apr 28, 2026 8:51 pm
Thanks. I have some cells on order but may have to opt for a pre-made item.
stephen_usher wrote: Tue Apr 28, 2026 8:51 pm Note that the charging system is very crude, just using a resistor and crossing fingers
Yeah I remember!
Also it doesn't run off the charger and requires the battery to be charged IIRC.
rubber_jonnie wrote: Tue Apr 28, 2026 9:54 pm Also it doesn't run off the charger and requires the battery to be charged IIRC.
Indeed, like many systems of its age.
stephen_usher wrote: Tue Apr 28, 2026 11:49 pm
Quite.
Annoyingly I'm in the office today so not much happening with this.
