2.2 booster question
Help & information about the V2.X series boosters.
Bikerbob
Re: 2.2 booster question
Post by Bikerbob »
So Pin 13 does have 5v on it, then of course you connect it to GND.. so since you say it needs 5v.. I assume OPEN is 16mhz and closed is 8mhz.
I will have to get my scope back out. but pin 1 of what chip? pin 39 of the shifter should have 16mhz on it right.. and that line goes to pad1 and so it should how up on pin 1 of CPU?
James
pin1 of the GAL you are measuring pin 12 on for 5V.
Bikerbob
Post by Bikerbob »
exxos wrote: Fri Mar 07, 2025 8:58 pm pin1 of the GAL you are measuring pin 12 on for 5V.
AH.. ok.. got ya. Ill check that. one other funky thing.. not sure if its Booster or H5C1 - but Tos 206 from the booter will set the date to 2028 everytime. I am using a ACSI2ST device so it uses US_GET.TOS to get the time from the device. in TOS 1.04 from the booter, works fine, any date I set and save I can recall. in 206 I can set the year to 2021 .. it says 28.. 25 it says 28.. kinda weird.
Just ran Gembench 6 and Im getting really good results even though the computer is only reporting 8mhz. is this correct? is only the CPU running at 16mhz? does sysinfo not report the speed?
James
ACSI2ST isn't a project I am familiar with.. You would have to report issues to its creators..
Results and sysinfo I already mentioned...
https://www.exxosforum.co.uk/forum/view ... 51#p125522
Bikerbob
Post by Bikerbob »
exxos wrote: Fri Mar 07, 2025 9:24 pm ACSI2ST isn't a project I am familiar with.. You would have to report issues to its creators..
OHHH im sorry CHris, I missed that somehow.. yes.. thats what I am getting.. ok.. so no-one ever said anything was funny about the clock with the booster or board.. cool.. Ill deal with it.
Thanks again for responding..
James
Return to “ST 16MHz V2.X SERIES BOOSTERS (Discontinued 2020)”
