RISKY MSX Rev2
Home for the Terriblefire MSX clone
ahmsx
Re: RISKY MSX Rev2
Post by ahmsx »
ahmsx wrote: Sun Jun 01, 2025 7:15 pm I started to work on an acrylic case for the RISKYMSX cartridge.
I already assembled the first prototype, but added a few tweaks which I want to validate.
https://github.com/herraa1/msx-riskymsx-enclosure
I built and validated the enclosure with the latest tweaks and added documentation to the github repo. Now handling the RISKYMSX cartridge is more comfortable ;)
arkadiusz.makarenko
Re: RISKY MSX Rev2
Post by arkadiusz.makarenko »
I don't get any new bug requests or new feature requests any longer.
There is like 2.5KB firmware flash left on the device itself, so not really enough to implement anything serious.
I managed to push this device to it's limits so I don't think I am able to squeeze anything more out of it.
I feel that this project is completed now.
This means that from now on I am planning only to provide basic support for it. I still have it on my bench, but I am planning slowly to clear it off, and prepare space for something new.
~ Stanislaw Lem
arkadiusz.makarenko
Re: RISKY MSX Rev2
I have made some more progress on firmware.
Now I can support Nextor. You need to have 128K mapper ram to run full Nextor, otherwise it will default to DOS 1.
It transforms connected USB into a drive. You need to format and configure drive as Fat16 and it works. I have tested it with up to 4 2GB partitions.
It is Nextor V3 Beta 2. I will update to release as soons as it is available.
I have exposed SCC in Nextor config as well, but I cannot make it to be auto detected, but if you set it up manually it works.
Tested on Sofarun and Trilotracker.
~ Stanislaw Lem
arkadiusz.makarenko
Re: RISKY MSX Rev2
Since I have some flash space to work with, I can add few features.
Menu now has alfabetical order of files ( It was fat16 order)
I have added mapper auto detection. It never will be perfect but better than guessing.
~ Stanislaw Lem
Re: RISKY MSX Rev2
arkadiusz.makarenko wrote: Sat Oct 24, 2026 9:30 pm Since I have some flash space to work with, I can add few features.
And all good stuff, happy to see you still working away on this.
Will have to figure my MSX out again at some point.
arkadiusz.makarenko
Re: RISKY MSX Rev2
PhilC wrote: Sat Oct 24, 2026 10:00 pm
I started working on 8MB 200mhz version of the cart, and I have implemented quite few things on it. Unfortunately this chips is in practice unobtainable at this time,so I decided to backport few things to this version.
LLMs helped me find ways to shrink the firmware, so I got like 7KB flash space back that I am slowly filling with new features.
~ Stanislaw Lem
Return to “TFMSX”
