RISKY MSX Rev2
arkadiusz.makarenko
- Moderator Team
Re: RISKY MSX Rev2
It turns out one of chips is damaged. It works fine on all other devices I have at home. There must be some internal issue with flash
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
Re: RISKY MSX Rev2
@ahmsx Thank you for expanding on docs and building guide. I have included your PR in the main respiratory.
~ Stanislaw Lem
~ Stanislaw Lem
ahmsx
Re: RISKY MSX Rev2
Thanks.arkadiusz.makarenko wrote: 01 Jun 2025 17:15 @ahmsx Thank you for expanding on docs and building guide. I have included your PR in the main respiratory.
I started to work on an acrylic case for the RISKYMSX cartridge.
I already assembled the first prototype, but added a few tweaks which I want to validate.
https://github.com/herraa1/msx-riskymsx-enclosure
arkadiusz.makarenko
- Moderator Team
Re: RISKY MSX Rev2
So there is something unusual with this chip.
Some devices do allow fast erase and some don't.
It is not related to chip version as I can see the same behaviour on v303 and v307.
Page erase works always, block erase 32KB does on some.
It is fluffy rabbits mental! It drives me crazy that I can't make it work as I want and how it is described in producers docs.
On the other hand what should I expect from a chip which cost less than £2...
So it is that on some chips when I erase above 128KB flash using block erase whole chip got wiped. Like I would issue whole chip erase function.
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
Re: RISKY MSX Rev2
I got it!
Flash can run up to 120Mhz main clock speed reliability at writes.
I run core at 144Mhz, so some can't handle it and crap out during flash erase operations.
There is section in docs about it so hopefully I should be able to fix it somehow.
~ Stanislaw Lem
~ Stanislaw Lem
ahmsx
Re: RISKY MSX Rev2
Nice to hear good progress on the flashing front!arkadiusz.makarenko wrote: 03 Jun 2025 22:57 I got it!
arkadiusz.makarenko
- Moderator Team
Re: RISKY MSX Rev2
Yes. After following advice from docs everything works as expected now.
I will test some more this and will release it hopefully tomorrow.
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
arkadiusz.makarenko
- Moderator Team
Re: RISKY MSX Rev2
@ahmsx New release allowing fast flashing.
https://github.com/arkadiuszmakarenko/R ... tag/v3.2.1
~ Stanislaw Lem
~ Stanislaw Lem
ahmsx
Re: RISKY MSX Rev2
Works fine here, thanks Arek.arkadiusz.makarenko wrote: 04 Jun 2025 17:50 @ahmsx New release allowing fast flashing.
Flashing large ROMs seems faster now (the smaller ones flashed already fast enough IMHO).
I looked at the datasheet for the CH32V30x and the typical flash endurance is about 80K (measured, not guaranteed) with a minimum guarantee of 10K.
So I think we can expect the RISKYMSX cartridge to last more than 20 years, even if we flash 10 full sized ROMs per day ;)
Let's see if mine gets to the MSX GOTO60.
Users browsing this forum: CCBot and 3 guests
