RISKY MSX Cart - Rev 1 (Beta Release)
arkadiusz.makarenko
- Moderator Team
Re: RISKY MSX Cart - Rev 1 (Beta Release)
New PCB arrived
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
I have it working now.
It is time to calculate opamp operation.
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
First try with opamp and few caps. It is step in right direction.
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
Few small tweaks and I am really happy with the outcome.
~ Stanislaw Lem
~ Stanislaw Lem
That music sounds so much better now, well done.arkadiusz.makarenko wrote: 24 Feb 2025 22:42 Few small tweaks and I am really happy with the outcome.
arkadiusz.makarenko
- Moderator Team
From what I can hear I don't have to worry about boosting bass on SCC circuit, but it looks like it would benefit from suppressing high frequencies.
On some PCB builds I can hear slight hiss when working with USB device.
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
I have built whole batch of them. Not too bad, just I don't know If I want to do it too often.
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
New firmware released. It fixes audio glitches and background noise which was annoying me on flashing pages
It was present only on some boards.Fixed by simply by always configuring DAC , not only for mapper that uses it.
~ Stanislaw Lem
~ Stanislaw Lem
Cool, will test out tomorrow with the new board :D
So far so good with V2.02. There was some noise as you'd said before I did the firmware update and that's gone now.
Testing still in progress but this is great, well done.
