Yes, that's one of the symptoms, and the Joy demo sometimes has the same problem some of the time.Badwolf wrote: 08 Jan 2025 22:52 OK, I had a quick go with AceTracker with both DFB1 and DFB1X.
The screen had problems under acceleration on both of them with it failing to initialise probably three quarters of the time both under VGA and RGB interlaced modes.
Definitely a timing problem as it's not consistent and on the edge of working. Maybe it happens to be the phase between the motherboard clock and the accelerator clock at the time the CPU tries to interact with the DSP. The timings will change with the phase discrepancy between the motherboard clock and the accelerator one, which would be 2.5Hz for the 40MHz clock and 3 1/8th Hz for the 50Hz clock.
From observation it seems as if both Joy and AceTracker initialise the DSP just before setting the resolution and however they're doing this may be causing a problem on the bus which is preventing the video set-up from working.
