Indivision ECS v4 Live config mode.
Super way easy to fit screen to monitor.
It is activated with left shift, ctrl, and tilde. Screen moving and zooming with mouse.
IComp's Indivision ECS v4 RTG support
Re: IComp's Indivision ECS v4 RTG support
@utri007 My setup is an A500+ with a TF536. I know the 68030 has its limits, so I’m not expecting miracles. Firmware is up to date, and I’m running the latest P96 drivers.
My question is about RTG performance in games. For example, Foundation seems to run quite fast, but the screen flickers whenever I click on something. AB3DII only opens in a tiny window at the top-right corner unless I set the resolution to 320x200 (Even then, the gfx is distorted). OnEscapee is way too slow. Etc...
The desktop in RTG 1024x768 256 colours and WHDLoad in native modes work flawlessly.
Do you have any P96 settings you can share? I only have Displaychain set to ON. Rest is default.
Thank you.
Thank you.
You need to config screen modes with P96 Settings from Prefs. I check latter today if there is anything special. Latest 3.60 version has a annoying 25 sec delay whan changin screenmode from RTG to PAL. There is a fix coming to that.
Thank you. Interestingly, I don’t experience the 25 sec delay on my system. Switching between RTG and native modes is almost seamless, there’s a brief 2–3 second pause where the mouse doesn’t respond, but the screen itself comes up right away.
I’ve already set up and tested the screen modes, but so far I haven’t been able to get any RTG-compatible games to run properly. They’re either slow, flickering, garbled, or just refuse to work at all.
