Oldskool’s Raven and w32i issues
agranlund
Re: Oldskool’s Raven and w32i issues
Post by agranlund »
Oldskool wrote: 23 Nov 2024 11:31 @agranlund
Your card just arrived.
Tried it and it is perfect. So the Raven is perfect.
The card looks really similar to mine. One thing I noticed was that it fits a bit tighter in the slot than my et32.
Mine was a tiny bit loose in the isa connector.
So lets see what you find. Would be crazy if it works at your end. Or if it is the isa connector type (aliexpress)…
Lets see.
Nice! Your card is supposed to be in the country so hopefully I'll get it on Monday :)
All the cards I have tried requires quite bit of force to get in and out of those isa-connectors I used so fingers crossed it's maybe just a slight tolerance issue with the aliexpress connectors.
agranlund
Post by agranlund »
Your card appears to work here! :)
It feels like it requires a little less force to go into the ISA slot compared to some others but it still requires some determination plugging it in and out.
Then it was perhaps just a some small tolerance issue with the aliexpress connector compared to the ones I got from mouser.
Both our cards look like they're the same model so should we just switch with each other? I figure that would be a win-win for everyone as we don't have to post the cards again?
Oldskool
Post by Oldskool »
Thanks!
What a strange but positive result.
If it works for you we can leave it like this.
If you find any issues please let me know than I will send your card back ASAP.
Now I have finally have enough confidence to put it in a case😀
Users browsing this forum: CCBot, redpixel, semrush [bot] and 58 guests
